Old 04-16-2010, 10:04 AM   #1
06_hbyaris
Drives: 2006 Yaris 5 Door HB
Power window doesn't work
Hi guys,
My 06 Yaris has an aftermarket power window motors/switch install by a local shop. It works fine until yesterday I tried to use the switch to roll down the window won't move. What do I need to check? Fuse? Switch connection?
Thanks
06_hbyaris is offline   Reply With Quote
Old 04-16-2010, 07:31 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by 06_hbyaris View Post
Hi guys,
Thanks
could be a fuse, or a solenoid/actuator... or maybe even a relay depending on the aftermarket kit... I'd take it back to the shop and ask them to check it out, explain that you bought it there. If you live in a different place... find a shop that appears to be slow (not many customers) and ask them... if they are slow they're more likely to fix it quickly, and if it turns out to be a quick fix (like a fuse), probably won't charge much.
Old 04-16-2010, 09:53 PM   #3
Malifabian
Malifabian's Avatar
Drives: Yaris Sedan 2008
I totally agree ^^
Malifabian is offline   Reply With Quote
Old 04-16-2010, 10:02 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
When you activate the switch can you hear the motor engaging or there is no vibration from the door or sound?
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
From Manual Window/Lock to Power W/L eocintron Cosmetic Modifications (Exterior/Interior) 5 11-10-2009 11:31 PM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 11:06 AM
