Old 01-02-2015, 10:05 PM   #1
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Exclamation Excessive engine movement
Hey guys,
I have a serious problem.
Whenever I launched my car or dump the clutch, the engine bangs against the firewall.
I'm now afraid that I may break something. My friends told me changing the rear engine mount to a solid mount would solve the issue. Another option would be an engine damper however I can't find any for my car.
What do you guys think?
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 01-02-2015, 11:03 PM   #2
KTS
KTS's Avatar
Drives: Vitz RS
Your friends have the right idea. It sounds like the mount(s) are busted.
You can purchase a universal tq damper or one from another vehicle and fabricate custom brackets. U can use a piece of pvc piping or paper towel roll to determine where you want to mount the damper and what length damper to purchase. I believe there are 2 different length dampers available.
KTS is offline   Reply With Quote
Old 01-03-2015, 08:03 AM   #3
Ryze268
Ryze268's Avatar
Sounds like a plan, I'll see what we can do
Old 01-04-2015, 10:01 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
micro image sells the TRD transmission mount. Might be worth it if your hard on the drivetrain. An engine damper only slows the movement of the engine.
Old 01-05-2015, 06:52 AM   #5
Ryze268
Ryze268's Avatar
Thanks much, could you post a link to it plz?
Old 01-05-2015, 07:28 AM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
http://shop.microimageonline.com/TRD...RIS-trd-mm.htm
There should be a link to the lower trans mount at the bottom of that page.
Old 01-05-2015, 03:20 PM   #7
Ryze268
Ryze268's Avatar
Thanks much, Looks like I need to do some saving.
Old 01-05-2015, 07:56 PM   #8
KTS
KTS's Avatar
Drives: Vitz RS
I have an idea that will be a lot cheaper.....don't launch the car or dump the clutch
Old 01-06-2015, 07:01 AM   #9
bronsin
bronsin's Avatar
Quite. Especially after replacing broken parts!
Old 01-06-2015, 10:33 PM   #10
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Might be mistaken, but I think that I got the last dogbone TRD trans mount that Garm had. He still has the 2 engine mounts. rather than fabricating mounts why not look to get used ones if you don't wanna buy new? Have you checked ToyotaPartsZone.com for OEM?
P.S. Yup, I am still alive and kickin, haha
Old 01-07-2015, 12:29 AM   #11
mario98c
mario98c's Avatar
I filled my engine mounts with 3m urethane lol The engine moves but not a lot like when it have the oem mounts. Also there is a little vibration when the car is at idle. For 30 bucks I think is the best you can do. lol
Old 01-07-2015, 01:41 PM   #12
KTS
KTS's Avatar
Drives: Vitz RS
yup the 3m urethane works good and the vibration is not bad at all. almost no one but me notices the vibration
Old 01-07-2015, 09:00 PM   #13
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
I'm going with the 3M this weekend if it doesn"t work engine damper My luanches at the track are bad and burnout also... to much torque
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 01-12-2015, 08:30 AM   #14
Ryze268
Ryze268's Avatar
Did you fill all the mounts or just the one at the back?
Old 01-12-2015, 06:30 PM   #15
mario98c
mario98c's Avatar
I fill the transmission mount and the back mount also. I have some pictures of the entire process. I post them later.
Old 01-12-2015, 06:41 PM   #16
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Great!!! Love to see pics also
R-CaT
Project Yar 2ZR
Old 01-13-2015, 07:26 PM   #17
mario98c
mario98c's Avatar
Sorry for the delay.
This is the urethane that I used.
To remove the transmission mount you need to remove the battery and the battery bracket. It's easy to remove. You need to put a jack stand to hold the engine and then remove the mount. To remove the back engine mount you don't need a jack stand.
Before
After
I don't have pictures of the back engine mount but it's much easier to remove that the transmission one. Also you need to let the urethane cure 24 hours.
Old 01-13-2015, 08:15 PM   #18
Ryze268
Ryze268's Avatar
Really appreciate the posts mario
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 09:02 AM
Can I change my yaris engine from 1.3L to 1.8L Rami yaris Performance Modifications 9 06-11-2012 11:21 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 08:11 PM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 10:02 AM
