#1 | |
![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
Not sure if you guys know but I have embarked on boosting my 2NZ-FE, I have in 1ZZ injectors however while tuning with the AFC Neo, we're running into lean spots while under boost.
My tuner said that I should upgrade my fuel system but that's kinda expensive (I plan to do it, just can't right now). He then said bigger injectors and a bigger fuel pump should help. While looking up new injectors I found these: http://www.ebay.com/itm/11-12-SCION-...7a8065&vxp=mtr They looked weird compared to regular injectors and I was reading up on them, turns out they're AR engine injectors. Quote:
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
The 1ZZ injectors should be fine up to at least 8psi of boost. You more likely are having issues due to flow into the injectors (from the stock pump) or fuel pressure (ideally fuel pressure should increase by 1 psi for each 1 psi of boost). I have modified stock fuel pressure regulators for people to give them a cheap upgrade by increasing the pressure regulator from the stock rating (41-45 psi) to that plus their max boost (i.e. 43 to 51 for an 8 psi setup). By doing that you account for the maximum plenum pressure, but then have to pull a little fuel at lower boost to compensate for the extra pressure.
#3 | |
#4 | |
How many PSI of boost are you running? I usually have people ship me their regulators to adjust, as new ones are crazy expensive (about $80+). In your case, that would probably be cost prohibitive for the shipping time and cost.
I'll be running a maximum of 8psi
Is this the correct one: http://www.ebay.com/itm/Fuel-Pressur...b5f063&vxp=mtr
#6 | |
#7 | |
2ZR swap. DO IT! Ask how!
How do you verify the new pressure?
I have a test fixture that I built that uses a stock Yaris fuel pump to test the original and modified regulators.
Mr. 155 and climbing
I know that you are looking for a relatively quick answer, but I might still have my OEM regulator kicking around, or maybe I shipped it to Scott? Anyway, Cranky he actually had me ship my AEM 320lph to test it on his bench before I sent it back to AEM to confirm whether or not I was experiencing a faulty pump. AEM was pretty impressed when I talked to them about it.
#12 | |
