Old 01-24-2015, 05:42 PM   #1
yarisitis
yarisitis's Avatar
Drives: 2008 Yaris LB
14 inch Tires on 15 inch Rims?
My 2008 Yaris currently has 15" tires, Bridgestone Potenza P185/60R15 84T, and I need to replace them.
Is it safe or even possible to put 14" tires on it?
The 14" tires are a lot cheaper than the 15" ones and the salesman at the dealership I talked to told me you can't put 15" tires on 14" rims. Is that true?
If it is true, then so be it, I'll pay the extra money for the 15" tires. Just want to make sure I'm not being lied to.
yarisitis is offline   Reply With Quote
Old 01-24-2015, 07:45 PM   #2
No. 14" tires would not fit on 15" rims.
Old 01-24-2015, 11:43 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
You should be able to find a good tyre at a very reasonable price here. Plus, no tax or fees, and free/fast shipping to your door. Then find a local installer for $10 a corner.
http://www.discounttiredirect.com/di...e&rd=15&cs=185
Old 01-25-2015, 12:12 AM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
You could also get a set of 14" steel wheels from another import (older civic/toyota/mazda) and use those instead. I use 14" wheels for my winter tires, but that's because I run a really silly tire size (175/70R14).
Old 01-25-2015, 03:33 PM   #5
yarisitis
yarisitis's Avatar
What are you thoughts on the TMPS rebuild kits that they try to get you to purchase with the new tires?
More money for the tire shop or a necessity?
Old 01-25-2015, 04:29 PM   #6
CoryM
Drives: 2009 5-door, 5-speed
Rebuild kits replace the rubber seal, and the nuts which often seize on. On a Toyota where the TPMS sensors last a long time, I would replace the seals every time new tires go on.
Old 01-25-2015, 04:01 PM   #7
IllusionX
Drives: 07 Yaris Sedan Aero
The rubber seal and the battery have a finite lifetime. So it is a good idea to rebuild after all these years.
Old 01-26-2015, 02:56 PM   #8
yarisitis
yarisitis's Avatar
I have 60k miles on my Yaris. Would you still replace the TPMS sensors or wait till the second set of new tires?
Old 01-27-2015, 12:18 AM   #9
CoryM
You don't replace the sensors until they fail, but the sensor "sleeve kits" should be done to reduce the chances of leaks/corrosion.
Cheers.
Rims + tires for a 2007 Yaris sedan Shmomi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-18-2011 05:03 PM
what price to ask for my 15" tires and rims? roadrunner Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-18-2011 07:19 PM
Rims and tires on craigslist for 350 for bay area members YarisSedan California 0 01-12-2010 02:21 AM
New springs, rims and tires Stiv Yaris TS Talk 8 12-28-2009 10:40 AM
FS Brand New Stock rims w/ Tires FlintS Items for Sale by private party 10 09-24-2007 09:22 PM
