08-06-2014, 09:02 AM | #1 |
Drives: yaris Join Date: Jul 2014
clutch change
2007 yaris manual transmission
how much time does it take to change a manual transmission clutch? are any special tools required? I have about 75,000miles. i feel it slipping slightly maybe when its wet. how does it fail? does it simply slip and fail to grab? do bad things happen if i wait too long? at what mileage should I change the timing belt? thanks for help |
08-06-2014, 10:55 AM | #2 |
Mr. 155 and climbing
There is no timing belt. The 1nz utilizes a timing chain and not a belt.
Timing chains are built for the life of the car however while they can technically last longer, it is suggested that you change it at 200k.
08-06-2014, 10:58 AM | #3 |
The clutch swap shouldn't take more than a couple hours with a lift and tranny jack. I've dropped the clutch without dropping the engine, but it's almost easier to pull the whole engine and do the clutch on a bench, but that's my opinion of course. If you don't have a lift and you are a DIY sort of person then you are looking at 3-4 hours. If you haven't ever done it then double that for allowed time to be safe.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
need help on my 2008 yaris compress clutch | susucosp | DIY / Maintenance / Service | 0 | 05-15-2014 03:48 PM |
clutch change interval | goofy gorilla | DIY / Maintenance / Service | 5 | 10-11-2011 08:46 PM |
2006 Yaris 1.3 TR, 80k miles- Clutch need pressing to its end OR Gear change getshard | planet | DIY / Maintenance / Service | 0 | 08-15-2010 10:20 AM |
MJ dead | 90tsi | Off-topic / Other Cars / Everything else Discussions | 28 | 06-26-2009 02:20 PM |
