Old 02-05-2015, 07:13 PM   #1
attrapereves
Drives: 2010 Yaris 2dr 5spd
Manual transmission
I've had my car for about a week. I find the little Yaris with 5spd particularly difficult to drive smoothly.
Takeoffs are the most difficult. I either give it too much gas and the car slingshots forward, or not enough and it shudders a little.
What should the RPM be to start from a stop on flat ground? Also, around what RPM does this car prefer to be shifted?
attrapereves is offline   Reply With Quote
Old 02-05-2015, 09:07 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
This is different for every car.. I honestly don't shift by RPM anymore, just by feel.
Old 02-05-2015, 09:31 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
I do short trips these days. So my RPM idles at 1500rpm. I no longer need to give it "gas" to take off.
Because the IDLE is always different depending on engine operation/temperature, you have to adapt yourself.
Since i drive such short trips, when i get to drive around more, and the engine has time to warm up and idles at 650rpm, then I end up stalling once in a while. :P
Old 02-05-2015, 10:40 PM   #4
Kar98
Drives: 2011 Scion tC
You'll get used to it. The Yaris is actually the first car that I had where I have to follow the instructions of letting gas come and clutch go gently. Every other car, the clutch was pretty much digital, either on or off.
Kar98 is offline   Reply With Quote
Old 02-05-2015, 11:14 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
been so long since I have had the stock clutch that I can't almost recall. I can say that I agree the stock clutch is a PITA in my book though. The Drive-By-Wire system is a lot to blame too.
Old 02-06-2015, 06:57 PM   #6
Em_
Drives: 2007 Yaris
my hatchbach ised to idle at 550rpm and used to launch at around 1100 rpm saves a lot of wear
i have an automatic 4 door yaris now
fedup shifting
Em_ is offline   Reply With Quote
Old 02-06-2015, 07:19 PM   #7
Kar98
Well look at Canadian Monsieur Fancy-Pantalons here with his Canadian tach and manual transmission ;)
But seriously, 550 revs at idle? 1100 to shift? I don't have a tach in my Yaris, but pretty much every other car I had before idled around 950 to 1100 and I shifted at around five grand. Shifting up at 1100? Do you get mistaken for a geographical feature a lot? :P
Old 02-09-2015, 10:43 PM   #8
Em_
Drives: 2007 Yaris
From a stop yes 1100 driving like a grandpa
Old 02-09-2015, 11:24 PM   #9
nookandcrannycar
This procedure = fun, but = MPG .
Old 02-26-2015, 07:15 PM   #10
Kar98
Meh. I still get 35 mpg in the city.
Old 02-26-2015, 09:00 PM   #11
nookandcrannycar
Do you turn the engine off at red traffic lights ? (jk)
Old 02-26-2015, 11:49 PM   #12
edmscan
edmscan's Avatar
Drives: 2020 Corolla
Even though I have been driving a standard for over 30 years .. when I got the Yaris .... it was a bit touchy. I stalled it a few times.
But now I am pretty used to it and it works well. But it is definitely harder to use than my 1980 Toyota Tercel, 1980 Honda Civic or 1987 Honda Accord that preceded it.
My fave of them all ... it is a tie between the Tercel, Civic and Yaris. They were all great cars.
I shift at about 2500 rpm.
edmscan is offline   Reply With Quote
Old 02-07-2015, 09:20 AM   #13
IllusionX
Mine idled at 550 before I cleaned the TB.
Old 02-08-2015, 04:44 PM   #14
nookandcrannycar
Aha! I was wondering what the reason might be re my '14 idling at a higher RPM than my '07. I've never cleaned the TB on my '07 .
Old 02-08-2015, 05:14 PM   #15
nookandcrannycar
I agree with many of the points Debby and Deathegg have made. I've owned a Mitsubishi Galant VR-4, a Mirage/Colt, a Scirocco, a Suzuki Swift, and a GTI...all with manual transmissions. Each of those was easier to drive than either my '07 MT or my '14 MT Yaris. I'd think even the 2nd Gen Yaris would be a hard adjustment for a novice manual transmission driver. My '14 doesn't seem to have the 'notchiness' in 1st gear that the '07 does. I'm PGD at launching on a steep incline in 1st gear. Could do this even in my '07 (at least when it was 'younger'). With my '14...forget it. One of the ramps in the parking structure at The Galleria in Houston is pretty steep (it is so flat here, this is the only time so far that I've encountered this issue ). I was on it in my '14 in bumper to bumper traffic one day fairly close to Christmas. I had to use the parking brake during that experience to keep from stalling.
Old 02-07-2015, 11:01 PM   #16
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Mine idles around 650 ish
Old 02-07-2015, 11:14 PM   #17
fourbangingfun
fourbangingfun's Avatar
Manual transmission
Launch between 1100-1500 rpm when on zero slope, and little higher if going up a hill.
And usually up shift around 3k
fourbangingfun is offline   Reply With Quote
Old 02-08-2015, 12:31 PM   #18
MUSKOKA800
MUSKOKA800's Avatar
You'll get used to it. We all have. It's done by feel. Driving off is no time to be looking over at the tach.
The engagement of the Yaris is like none of the many manuals I've experienced.
After 6+ years and over 165.000 kilometers I still stall mine occasionally. Switching from one pair of shoes to another with different sole thickness often catches me out.
Automatic Transmission to Manual Zarkos Performance Modifications 3 05-22-2014 12:24 PM
Automatic or manual transmission bentjazz Fuel Economy Forum 31 03-03-2011 01:52 AM
changing transmission oil (manual transmission) mrb3990 General Yaris / Vitz Discussion 0 04-26-2010 11:08 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
