![]() ![]() ![]() Drives: US 2007 Yaris Liftback 5MT Join Date: Aug 2006
Yaris homebrew race car?
So next month (July) My Yaris turns 5 years old. I plan on keeping the care another 5 years. It will be LONG since paid off by then. A friend of mine says I should turn it into a track day car. Racing slicks, rims good for racing, even stiffer springs, and a little lower. I could remove the seats, spare tire interior, some of the dash board, radio, replaced the driver and passenger seats with racing seats, carbon hood, aaaaand turbo…
But… Should I bother doing this to a 10 year old Yaris? What kinds of other things should I be looking for? The engine will have about 200K miles on it. Should I have the engine rebuild, or maybe even drop in a new engine? What about the transmission? Would I need a new stronger gearbox? Granted 5 years is a long time from now, but I am mainly just curious to know if anyone has done any of these things, what all they did and how much it cost? Thanks all, - Jason
2007 Toyota Yaris Liftback Base 5 Speed. Mods: Netz/Vitz/RS badging, RS style spoiler, RS replica tails, Tenabe NT210 Springs, Tokico Blue Struts, Team Dynamics 14", fogs(Arrived), JDM HKS Exhaust. |
I say thats a good idea.. In the mean time, Id start looking for another 1nz-fe motor and break it down and rebuild. 5 years is a long time and PLENTY of time to really learn how to work on the 1nz. As a beginner, I'd rip it apart. Then put it back together, put it in your car to see if it cranks. If it doesnt, find out why. Then when you get it cranked, pull it back out, break the motor down to pieces again and repeat. Do this til you know it like the back of your hand.
While your doing this, start saving that money and buy your roll cage and suspension, tires and wheels. After 5 years, you will have a motor to put in that is more reliable. THEN, take taht 300k mile motor and break that down and ReBUILD for a TURBO... sorry, got carried away.. just a thought if i was in your situation. GOOD LUCK! |
#3 | |
Just call me Ray, better?
+1 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Ever thought about building it for land speed racing? A Yaris on the Bonneville Salt Flats might be fun. It might be hard to find a class that is not already dominated by hondas though.
![]() ![]() ![]() Drives: '08 LB, '07 WRX Join Date: Jan 2009
great idea! I have always toyed with the idea too. The wife proclaimed she wants the yaris for 10 yrs, after that its mine to do whatever with...
#6 | |
Mods are very limited: non-adjustable shocks or coil-overs (no compression or rebound adjustment) with max spring rates of 500lbs. Minimum 5" ride height measured at the lower sill. Max -2.5 front camber, can be done with crash-bolts or offset bushings. Drop-in air filter replacement. Cat-back exhaust. 15"x7" wheels (12lb minimum weight) with 205-50-15 R compound tires. Any brake pad and stainless steel brake lines. Also required is a six-point rollcage, racing seat, 5-point harness. Interior is all removed, except the dash. Even at 200k miles I would not bother working over the engine of trans, if it is running fine get out there and get experience, once it breaks fix it. ![]() ![]() Now if you have deep pockets go for H Production. You can go nuts on suspension. Change the gearing (actually replace the entire trans), clutch, flywheel, LSD. Carbon hood and hatch. Plastic windows. Flare it for 10" wide slicks. ECU is open, head work and cams can be done. The car will be just over 1800lbs and should make around 135hp NA. It is crazy fast, for a Yaris. We are into our second season with the car and the only mechanical failure has been an aftermarket crank pulley. The trans and engine hold up great. If you went with a turbo you might have more stress on the gearbox. ![]()
+1 on drooling
#9 | |
Wooooow man! Those are both great looking cars! 5 years is so far away, but if I was not making car payments, I could totally afford a track day car and my roomie has a truck. Thanks so much for all the information from everyone! Makes me wish I could do it now.
- Jason Quote:
2ZR swap. DO IT! Ask how!
I have been considering something similar. My '09 hatch was paid in cash, so I own it outright, but I need to finish college (3 more years) and get most if not all of the kids out of the house (10+ years) before I can really get into something as time and money intensive as racing. The kids part is flexible, as engineers tend to earn decent pay, but having a garage is a must, so moving out of the trailer and into a house is a must.
I hadn't thought about the class that I want to compete in, but I had thought about getting involved with SCCA for some entry level experience. |
#11 | |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
And SCCA is awesome. You learn so much about your car just by doing only a couple Auto-X events.
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#12 | |
I am just after a track day car. Something I can have a set of slicks in the back (or on a little tire trailer), bring a jack and tools, swap tires and have a fun day. Or maybe do an ECU, run premium gas, and leave the slicks on it and borrow my roomies truck and rent a trailer and tow it out there. How do you register/insure a track only car? Does it even need plates? It certainly would not legally pass smog. Can one remove the Cat?
#13 | |
Threw 4 rims/tires, a low profile hydrolic jack, ramps to get the front high enough to get the jack under the side skirts, torque wrench, breaker bar, a Makita cordless impact gun, and a bag of stuff (tire pressure guage, laser temp guage, lunch, bottle waters, sunscreen, camera, and my numbers/letters. |
#14 | |
Any way in hell that a Yaris could be hot rodded enough to go 150+ mph? |
![]() Drives: Black 2008 Yaris Sedan 5spd... Join Date: Sep 2011
2az-fe? Nice, strong good running engine! They make a ton of parts for them, including turbos, full head kits etc. Given you can fit one under the hood of our lil' yarii.
Then it wouldn't be H production class.. that is the Goal there, a 1nz getting to 150mph Naturally Aspirated.
![]() ![]() Drives: Black 2012 Yaris 3door 5speed Join Date: Dec 2011
And to think I bought my 2012 yaris to get me from point A to point B everyday as cheap as possible.
Now you've got me thinking. Thanks for that. lol
New to the Toyota World, be nice. |
god do i know what you mean.. I bought this car as a DD so I wont put money into it. 1st autocross event and my jaw dropped on the handling this thing has. So sad
| Gwasabi (Yoshi) - Photo-Scavenger Hunt! | gwasabi | Photo-Video-Media Gallery | 24 | 03-07-2009 11:23 AM |
| Darb - Photo Scavenger Hunt | Darb | Photo-Video-Media Gallery | 3 | 03-01-2009 09:02 PM |
