Old 07-23-2011, 04:47 PM   #1
Lil Abner
Drives: 2009 3dr LB Manual
Custom Rear Wiper Delay Circuit on Swapped Stalk
Ok, here's my final result. I used the information at this link:
http://www.kpsec.freeuk.com/555timer.htm#astable
I created an on cycle of 0.7 seconds, and an off cycle around 7 seconds. Only 3 wires were used to connect the module: Ignition (+), Ground (White/black on stalk), trigger (Blue on stalk). When the wiper switch engages the rear intermittent position, it feeds a ground to the circuit. The circuit takes that ground signal, and passes it through to the Blue wire for 0.7 seconds, every 7 seconds. Right now, I made the circuit non-adjustable. But it's easy to replace a resistor with a 500K potentiometer.
Bench Layout:
Soldered, before trimming the board:
In car, showing connections (thanks CTScott for pin-out):
And video, proof of concept:
http://www.youtube.com/watch?v=rxSQjWtRIx8
I think I calculated everything correctly, so there shouldn't be any issues in the future. All the parts can be found at Radio Shack. Price, I'm not sure. I buy in bulk, so I don't know what a Radio Shack total would run.
Old 12-10-2012, 06:23 AM   #2
birdman
Drives: '08 Blazing Blue Yaris LB
In one photo there is a red arrow pointing at something but it doesn't say what and the other picture has a red circle over a bunch of wires with no explanation. How is this helpful?
birdman is offline   Reply With Quote
Old 04-19-2015, 11:28 AM   #3
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I'm now attempting to build my own custom circuit.
Looking through the service manual, I managed to find this nice logic diagram:
If I'm looking at this right, all I need to do is build a timer circuit that connects wire L (blue wire) to ground wire W-B (white wire with black stripe) for a short enough time (0.7 sec according to the OP) that allows the wiper motor to close the contactor in the wiper motor assembly via the eccentric cam lobe. Once that happens, the wiper should return to its original position by itself and remain there until the circuit is once again closed by the connection of the L and W-B wires.
Something else to take under consideration, the circuit itself must be able to withstand a transient current that is above the fuse rating. (15A)
I'll start working on this project in the next few days.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
Rear wiper function, is this normal? Yaris Dick General Yaris / Vitz Discussion 7 11-08-2006 09:46 AM
