Old 07-03-2019, 09:35 AM   #1
bronsin
bronsin's Avatar
Question about radiator fan
The fan for my radiator comes on, but it spins very slowly. The problem is my air-conditioner only cools the air about 20°. Does this fan have a thermostat on it,?
Isn’t this fan supposed to spin at full speed? Inquiring minds want to know!
Old 07-03-2019, 09:55 AM   #2
tmontague
tmontague's Avatar
There are 2 speeds controlled by two separate relays.
Iirc the fan should spon fast when the a/c is on
Old 07-03-2019, 10:03 AM   #3
bronsin
bronsin's Avatar
I see. Maybe it’ spins slowly when it’s not so hot Like this morning?
Old 07-04-2019, 01:19 AM   #4
komichal
When I turn the AC ON, the fan starts to spin slowly (and it cannot be heard over the idling engine). But usually in a minute or two the fast spin kicks in and the fan noise overwhelms the engine noise.
Still, it takes up to 5 minutes for the AC to start blowing the cool air if the car has been parked for 24hrs. Toyota authorized service center found no problem with AC components, nor did another independent service guy. So I just assume the AC of this 12-year-old can has been designed this silly way or it is simply too old.
Old 07-05-2019, 08:11 AM   #5
bronsin
bronsin's Avatar
no matter how hot it is Or how long you wait, my fan never kicks into high. We’ll see what the shop says tomorrow
Old 07-06-2019, 02:53 AM   #6
Bony_ahmed
Drives: Toyota Yaris SEdan
check the fan relay first, this happened to me once......my fan relay was bad
Bony_ahmed is offline   Reply With Quote
Old 07-05-2019, 09:42 AM   #7
toyotavios_11
Drives: Toyota Vios
if a/c high pressure more than 190psi, radiator/condenser fan will spin at fast speed
toyotavios_11 is offline   Reply With Quote
Old 07-05-2019, 05:12 PM   #8
tmontague
tmontague's Avatar
If that is the case then maybe the OP's pressure is a bit low
Old 07-07-2019, 09:15 AM   #9
BLH
Drives: 2007 Yaris Sedan
In my 2007. The fan is turned On by a relay and has a resistor is in series with the fan motor. Lowering the voltage to the fan motor. That give you low speed fan.
A second relay shorts out the resistor so full voltage is on the fan motor. It could be the relay that shorts out the resistor for high speed fan.
BLH is offline   Reply With Quote
Old 07-07-2019, 08:26 PM   #10
toyotavios_11
Drives: Toyota Vios
Relays are located at fuse box in the engine compartment and the resistor is located at right behind the left head lamp which is in between the lamp and intake box.
Old 07-08-2019, 03:59 AM   #11
bronsin
bronsin's Avatar
Unfortunately problems with my medication lead me to cancel mine appointment with the mechanic.
I’m thinking I will replace relay number two Myself. Can someone give me the part number? Thanks!
Old 07-08-2019, 06:21 AM   #12
toyotavios_11
Drives: Toyota Vios
85928-52030 RESISTOR, COOLING FAN
90987-04004 RELAY, COOLING FAN, NO.2
Old 07-08-2019, 08:47 AM   #13
bronsin
bronsin's Avatar
Perfect!
Old 07-08-2019, 10:13 AM   #14
tmontague
tmontague's Avatar
One of the fan relays is not located in the under hood fuse box and I cant remember of hand where it is located but I remember is being built into a module and it is not a simple relay swap
Old 07-08-2019, 11:54 AM   #15
bronsin
bronsin's Avatar
I consulted my 2001 Toyota Echo service manual and they have a procedure to test the relays. You test circuit 1-2 for continuity. Then you put 12 V on it and test the other circuits for continuity.
Relay one is stuck and won’t come out. Relay two isa smaller and hard to get a hold of.
Old 07-08-2019, 03:40 PM   #16
bronsin
bronsin's Avatar
I got relay two out And the last five numbers of the relay are indeed 04004. Now I have to get some alligator clips so I can test the relay and see if it’s bad
Old 07-08-2019, 09:38 PM   #17
bronsin
bronsin's Avatar
Here is the relay
https://www.amazon.com/90084-98032-9.../dp/B07NPK263X
Old 07-10-2019, 08:57 PM   #18
bronsin
bronsin's Avatar
A new fan two relay didn’t fix the AC.
Or make the fan run fast it only runs slow
Hubcap question 2009 Yaris Sedan- URGENT mrs_yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-13-2016 03:21 PM
License Plate question awebb005 Cosmetic Modifications (Exterior/Interior) 5 11-11-2014 09:28 AM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 01:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 04:57 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
