#1 | ||||
Transponder key programming
Hey folks, does anybody know how to program a new transponder key without needing to take it in to the dealership?
I bought a new key with the keyless entry remote off eBay some months ago and finally got around to getting the key cut. The keyless entry bit is programmed, easy to do with CTScott's instructions and they key is cut. It opens the doors and cranks the engine but as expected does not start it. The engine immobilizer definitely doesn't recognize it as the light on the dash continues blinking. Here are the instructions I've tried (copied and pasted from other sources). I was feeling pretty good about #2 but it did not work. I didn't give any of these more than one try because it was way, way too hot to be sitting in the car. Quote:
advocatus diaboli
I'm also curious, I have a blank sitting here...
If you look at the "Engine Immobilizer" section of the service manual, it appears that you can only register the first master key to a new immobilizer ECU without the TechStream tool. To add additional keys to an immobilizer ECU that already has keys registered requires the TechStream tool.
That's how I read the service manual too, but I was hoping perhaps I was misinterpreting it or that there was another way. I might give these methods another shot... just in case I get lucky.
I'm planning to bring the car in for it's 64000km maintenance service next month and will probably just bring the key in then. They quoted me $44.50 to cut the key & program the transponder + remote. Since I've done the cutting and remote hopefully it'll be a bit less. The price seems reasonable (at least less than I had expected), the quote was for 0.5hr labour. |
#5 | |
advocatus diaboli
Oh, 44.50 isn't as bad as I thought it would be...I can deal with that too I guess, considering the blank was like 8 dollars.
I went to get an extra key from a dealership once and they wanted around $150 for it. that was for the key and all. I then found the joy of ebay. the key was more of a curiosity as I really needed the key fob.
amazing what they want for those little suckers. (it was on a nissan but I figure they are all about the same) |
![]() Drives: Yaris CDX 1.4 D-4D 09/2002 Join Date: Apr 2015
Hi,
I have a Yaris from 09/2002 CDX 1.4 D-4D UK and recently replaced a falling apart original black remote key case with one that was cut by carkeyhelp.co.uk from a tag number attached. All the other keys have been lost by previous owners. To my surprise the new blank key was cut perfectly and all is working fine despite a couple of bad reviews of this website. Now, after reading some forums that it costs about £200-900 to replace ECU if I loose my only master key I got back to them to enquire about a transponder key (they said they'd not get a good price for new remotes and that should get from Toyota). A transponder key with no remote is about £18 including cutting so this is the most optimal option for a car worth mere £1400. The problem is that instructions to determine which key I have from these guys/internet don't match i.e. they say after inserting master key into ignition without turning the security light should go off instantly but it keeps flashing as if no key was inserted. Also, if it was a valet key the security light would go off after 2 seconds so it's not the one I have either. Then last one states that if my key is unprogrammed the security light would keep flashing. This is what's happening in my case but with this key I can operate all functions and start my car (have been using for the past 3.5 years). So, none of the three information is correct in my case and the security light only goes off instantly when I turn my key to ON position when all dashboard lights come on. Therefore, am now puzzled and not certain what key I have and whether it's worth getting another one cut with transponder that can be programmed using various techniques available on the internet. Last edited by davss; 04-28-2015 at 07:14 PM. |
| Lost key (transponder and remote lock/unlock) | shyeoh | DIY / Maintenance / Service | 4 | 07-11-2013 05:04 AM |
| Reemplazo Swichera | yukardo | Central and South America | 3 | 04-03-2011 12:11 AM |
| Need remote key | fraenx | DIY / Maintenance / Service | 1 | 06-26-2009 07:29 PM |
| Debunked: dealer only transponder key "myth" PICS | auxmike | DIY / Maintenance / Service | 31 | 12-11-2008 08:34 PM |
| Yaris transponder key: do we ALL get one?? | auxmike | DIY / Maintenance / Service | 10 | 12-01-2008 10:40 PM |
