Old 06-23-2013, 08:53 AM   #1
ciscobear
Drives: Toyota Belta
Starting issue with 1kr-fe engine
Hey guys/gals, watch the uploaded video and give me your thoughts on the possible problem.
http://youtu.be/w1vJ-WFDtDo
ciscobear is offline   Reply With Quote
Old 06-23-2013, 09:10 AM   #2
ciscobear
Plugs were changed to correct spec, starting motor cleaned up and lubed, gas tank filter was cleaned. No diagnostic codes revealed. Additional grounds were added, battery changed last year. Still the problem persists especially on a colder morning, keep in mind however our ambient temps are around 28 degrees Celsius. Throttle body was cleaned as well.
Old 03-07-2015, 12:39 PM   #3
floringvrl
Drives: yaris
The same problem i have at my 2007 Yaris with the same engine, and it doesnt matter if the engine is cold or hot. How do you fixed the problem?
thak you
floringvrl is offline   Reply With Quote
Old 06-23-2013, 10:46 AM   #4
The service manual for the 1KR-FE points to that kind of a cold start issue being caused by fuel pump issues.
Old 03-09-2015, 05:06 AM   #5
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
I had this too only once a few weeks back... how many km's / miles do you have on your car? Mine has 86 000 KM and a friend told me this could probably be the ignition distributer getting ''old''... If this happens to me all the time then I wille replace that part first.
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 03-10-2015, 02:45 PM   #6
floringvrl
Drives: yaris
98 000 km manufactured in 2007 how can i be sure is that? On a computer test it have no errors.
Old 03-11-2015, 04:50 AM   #7
woops
Drives: Jeep Cherokee XJ 1996
you need to check the fuel pressure using a pressure gauge
if the fuel pressure is OK only then you can test further
the 1kr has nothing known as the ignition distributor
woops is offline   Reply With Quote
Old 03-11-2015, 01:44 PM   #8
shepd
Drives: 2007 Yaris 5 door RS
The Yaris is coil on plug, rather than using a distributor. However, those can get weak/break. I don't know if the Yaris is prone to that or not, but it doesn't hurt to take a look. They're easy to get to.
shepd is offline   Reply With Quote
Old 05-03-2015, 01:31 PM   #9
Mikastef
Drives: Yaris
I have exactly the same problem and the SAME engine.
when starting my car from cold start or from a long rest (e.g. >5hours), I get this sound.
I went to see a car mechanic and electric expert.
The Mechanic did not find the problem since when I already start the car to go to the mechanic, the problem does not come back again (remember-- You need to have the car rested for >5hr approx.)... so mechanic couldn't get the problem to come back in order to detect it.
I went to see a car electric expert. Starter was serviced and everything checked.
Problem still occurred after the servicing.
But what I did to resolve the problem now is:
Every time I have to start the car out from cold, I accelerate gently and at the same time start the car.
PROBLEM SOLVED! Car starts at first ignition and problem NEVER reoccurred.
I think the problem is maybe the fuel pump or fuel goes back to the fuel tank after a long rest (it does not stay in the fuel line up to the accelerator pedal - hence the reason it takes some times to start in the morning since the fuel pump starts pumping fuel when you start the car...).
Mikastef is offline   Reply With Quote
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
2002 diesel, problem starting when engine is hot casadelaloma DIY / Maintenance / Service 0 10-18-2010 08:48 AM
Weird starting issue 2007 auto yaris Nask26 DIY / Maintenance / Service 11 07-28-2010 12:29 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
