Old 04-29-2015, 09:04 AM   #1
meperson
Drives: 2007 Toyota Yaris
Proper Referigerant Pressures
My 07 Yaris Sedan is blowing warm air when I turn on the A/C. Before I bring it to the shop, I want to check the pressures and see if a recharge might fix the issue, but I can't seem to find proper refrigeration pressure anywhere. Does anyone have the spec for low side pressure?
meperson is offline   Reply With Quote
Old 04-29-2015, 09:43 AM   #2
tmontague
tmontague's Avatar
Is it not under the hood on the sticker?
Old 04-30-2015, 06:04 PM   #3
I posted it in a bunch of different ac threads. I don't have it handy.
Old 04-30-2015, 07:26 PM   #4
beaker
Drives: 07 Yaris 3 door
There's not really a concrete right answer to your question, as the pressure reading on you gauges will fluctuate depending on temperature, elevation, and other atmospheric variables where you are. Your gauges will read different when it's 70 degrees outside than when it's 100 degrees outside. Generally though, your low side readings will correspond with the temp coming out of your vents, roughly. If your high and low are equalized(reading the same), then something is wrong.
beaker is offline   Reply With Quote
A proper introduction Captain Slow General Yaris / Vitz Discussion 13 12-13-2011 02:46 PM
On tire pressures, the Yaris, and the Prius sbergman27 Fuel Economy Forum 18 04-05-2010 05:35 PM
How to determine proper wheel offset? Yaris Revenge Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 05-23-2009 10:41 AM
proper wheel size/offset based on spring drop. marcus Performance Modifications 4 03-27-2009 10:33 AM
Proper coolant level? jay DIY / Maintenance / Service 4 03-22-2009 04:23 PM
