Old 12-20-2013, 11:14 PM   #1
AT to MT Conversion Kit Clearance Sale
I now have two complete Automatic to Manual transmission conversion kits on hand and really need to free up some space, so I offering them for a small fraction of the sum of the parts.
Price per kit: $400 plus shipping
One kit left - Clearance special: $250 + shipping
Kit includes:
Clutch and Flywheel:
Shifter and Shifter Cable:
Clutch and Brake Pedals:
Clutch Master and Slave Cylinders and lines:
Brake Master Cylinder:
Brackets and Hardware:
Optional:
2007-2008 MT ECM (programmed with your car's VIN): $50
If you have a 2009 or newer you will need to purchase an appropriate ECM from ebay, junkyard, etc. If you ship it to me I will reprogram it for you VIN for no charge.
C150 Manual Transmission (one available, needs rebuilding as synchros are bad): $100 + shipping
Old 12-21-2013, 06:40 PM   #2
Astroman
Modded Moderator
Astroman's Avatar
Hm that's a pretty good deal.... do you have an idea what it would cost to have the trans rebuilt?
Old 12-21-2013, 10:30 PM   #3
No idea what a rebuild would run. The sum of the synchro rings looks to be about $150.
You could also pick up a used good MT from a local junkyard. They tend to run about $250 to $350 from what I have seen.
Old 03-24-2014, 10:16 AM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I can tell you that so far from my research since I burned through my first C50 it was going to run me in the neighborhood of 1k-1200 to do a rebuild with two new gears from the Vibe. A good portion of that cost will be the tools as I have been informed at the least there is 400 in specialty tools alone. The biggest issue is that there really isn't a call for C50 rebuilds so most shops would need to procure the proper tools.
Old 12-22-2013, 12:26 PM   #5
That's awesome Scott. How many kits do you have on hand?
Old 12-22-2013, 01:17 PM   #6
Two kits. One from a Yaris that I parted and one from one that I did a MT to AT conversion on.
Old 12-23-2013, 03:29 PM   #7
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Man....
If I wasn't balls deep into rebuilding my truck's engine I'd buy one of these.
Old 12-23-2013, 06:56 PM   #8
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
What's the shipping weight if you don't mind me asking? :)
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
Old 12-23-2013, 08:12 PM   #9
With the clutch and flywheel it is 68 lbs.
Old 01-01-2014, 11:26 AM   #10
scottbebadboy
Drives: 2007 Toyota Yaris HB
Scott. Is it very expensive to go from manual to auto? How hard of a job is it?
scottbebadboy is offline   Reply With Quote
Old 01-01-2014, 11:45 AM   #11
What I have spent doing the manual to auto conversion is:
1. Automatic Transmission: $300
2. AT Shifter Assembly: $75
3. AT Shifter Cable: $107
4. AT Rear Frame Mount: $22
5. Shifter Cable mounting brackets and AT cooler hoses: $67
6. AT Wiring Harness: $80
7. AT ECM: $50
8. AT Brake Pedal: $50
9. AT Flywheel: $25
Labor-wise it is not that bad, as in my case I already had the engine out.
Old 01-01-2014, 12:58 PM   #12
yarisgeo13
yarisgeo13
Drives: gloss black 5 door
Send a message via Yahoo to yarisgeo13
Not bad idea but where I live, it's to much traffic and way to many stop lights to warrant a switch. I'll keep my car the way it is, stock auto transmission.
yarisgeo13 is offline   Reply With Quote
Old 04-01-2014, 01:23 PM   #13
White lighting
Drives: 2009 pearl white yairs Rs
Do you still
Have any left?
White lighting is offline   Reply With Quote
Old 04-01-2014, 03:06 PM   #14
Originally Posted by White lighting View Post
Do you still
Have any left?
Yes.
Old 04-01-2014, 02:43 PM   #15
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Well, it doesn't get much easier than that...
Bravo
-Type 07 FFL-
My odometer 03/11
Old 11-18-2014, 02:52 PM   #16
I still have one of these kits left and to get it out of my garage, I will let it go for $250 + shipping.
Old 11-18-2014, 10:47 PM   #17
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Can I put it on layaway? I just started my first "real" job as a salaried engineer, and I'll have some money to play with in about 2 weeks.
Old 11-18-2014, 11:01 PM   #18
Sure. And, congrats on the new job!
Tags
automatic, manual, transmission conversion
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
NOS kit for sale cali yaris Items for Sale by private party 24 07-06-2009 06:16 PM
