rear hub spacers
Has anyone had any luck sourcing these now that MI is out?
I don't want to install wheel spacers but I like the hub spacers. If I can't find them anywhere is it a bad idea to just use washers and find longer hub bolts to essentially do the same thing? |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Just use the right thickness wheel spacers. We use them with 500whp applications on Audi's. Really no issues especilly a Yaris and the rear too.
I don't like the idea of having 8 bolts instead of 4. I'm also not a fan of having the wheel too much further out from the bearing in regards to bearing life.
That's why I like the hub spacers so muc. No extra hardware other than longer screws. |
#4 | |
For a hub spacer, your idea of washers is not ideal since you wouldn't have full face contact and all the stress would be on the 4 bolts only. |
Good point about the washer idea. I just don't feel fully safe with wheel spacers. I plan on buying new rims. For my Yaris next summer so i'll likely just run a 35 offset and maybe more in the rear instead of running spacers.
rear hub spacers
You don't need the wheel spacers that bolt to the hub and then bolt the wheel to the spacer. I've been running 10mm ichiba wheel spacers for a lot of years with no issue. Only had to replace stock studs with ones 10mm longer and good to go.
Where'd you get the longer studs from?
rear hub spacers
^ Napa. Somewhere on here I have posted the part# of the stud bolts I got from them. Search 'napa stud' and I believe you'll find the thread.
Will do, thanks!
have a set of hub spacers 10mm with bolts used that i got used but have not used...just lazy plus dont feel like getting new wheel bearings lol to do the job and yes u will need a set on a winter driven cars that have seen few winters .
They sit behind the hub just what ur looking for if interested . |
| Rear Hub Spacers | Banana Man | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 02-27-2015 05:54 AM |
| Rear hub spacers | Stiv | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 03-01-2010 11:54 AM |
| question on Rear Hub Spacers | mastaofdisasta | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 02-02-2010 09:54 AM |
| Penguin Garage Rear Hub Spacer Raffle!! | Penguin Garage | General Yaris / Vitz Discussion | 27 | 06-30-2009 01:05 AM |
