![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
1ZZ TB without intake???
im about to upgrade to 1zz tb but i do not want intake kit just like the picture i have attached below..i had simota intake and i took it off after 2 days due to annoying humming sound and losing low end..is it true that i will not gain hp and it will be too restrictive with stock airbox??
does anyone have TB with stock airbox?? ![]() Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
I don't have a stock filter anymore, but I'm quite sure it's too restrictive for the TB to do any good. Heck, even with an aftermarket intake, the gains are quite moderate without a full exhaust revamp.
I installed an aftermarket SRI, 1ZZ TB, aftermarket header, and custom exhaust (in that order), and only after I swapped the exhaust did I feel a tangible difference performance wise.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
I have a 1zz TB, and to be honest if you have no other supporting mods then the only advantage is an increased throttle response (this is not an increase in HP). I noticed a very significant difference when I ported my stock intake manifold (which I'm now selling). I now run the MicroImage/Golden Eagle manifold which is also built to match the size of the 1zz TB.
I personally don't think the stock airbox will be restrictive. The engine is a vacuum and i feel the stock airbox is large enough for the amount of air the 1nz needs even with the 1zz TB. That being said this is because even with a 1zz TB, you are still severely limited with the stock intake manifold. The engine is can not use more air because of a 1zz TB, it is still limited by intake and exhaust manifolds. IMO, the 1zz mod is useless (except for throttle response) without porting your intake manifold or running the microimage manifold. In your case the restriction is not the airbox but the stock intake manifold.
#4 | |
2ZR swap. DO IT! Ask how!
Also keep in mind that the stock MAF sensor (and the tube it lives in) will always be the limiting factor on the intake side. The diameter is part of the formula the ECU uses to determine air-fuel ratios, so it's hard linked to the ECU. The only way to get more air past it is with a compressor--and even then you'll just throw MAF out-of-range errors. =)
feed my pet
I am using 1ZZ TB with stock air box at first. Later on added a TB spacer as port matching.
rabbito did you see that Thai intake manifold? Any idea on the diameter for TB side? |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
MAF from a 1ZZ is the same part number as for the 1NZ, Just the tubing diameter is different
#8 | |
im not sure about the size.. Sent from my ASUS_Z00AD using Tapatalk
#9 | |
It's like trying to suck in a milkshake through a thin twisty straw as opposed to a fat straight one. You could (hypothetically) swap your lungs for a bigger set, but with the twisty straw still in place, the overall improvement will be negligible. My advice is to start with a SRI, then go to the TB, then mani, then header, and finally either an axle-back or header-back exhaust (if you're really looking to push it). It's definitely the more expensive route, but you will feel a difference in all areas as a result. My 2¢.
| JB Weld stock intake manifold port w/ 1ZZ Throttle Body | tmontague | Performance Modifications | 2 | 10-07-2015 09:31 PM |
| 1zz intake manifold | crazylegs | Performance Modifications | 7 | 08-02-2015 08:02 PM |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| Intake to match the 1ZZ throttle body | fuji | DIY / Maintenance / Service | 2 | 06-17-2009 10:02 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
