Old 09-08-2015, 05:52 PM   #1
attrapereves
Drives: 2010 Yaris 2dr 5spd
Wheel pulling
For as long as I've owned this car, I've had to keep the wheel turned slightly to the left to make the car go straight. If I release the wheel, the car will usually veer to the right. I do not see any abnormal wear on my tires. The roads here have their highest point in the middle, with a slight slope down towards the curb (I'm assuming for rain).
Does anyone else notice this with their Yaris?
attrapereves is offline   Reply With Quote
Old 09-08-2015, 06:34 PM   #2
MUSKOKA800
MUSKOKA800's Avatar
The car should gradually drift right due to the crown in the road. If it veers then you no doubt need an alignment.
Old 09-08-2015, 06:58 PM   #3
attrapereves
Would a shop be able to visually tell me if I need an alignment without actually doing one? I don't want to pay for an alignment only to find out I don't need one.
Old 09-08-2015, 07:36 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
No ...and by the sounds of it u need one .
Old 09-08-2015, 09:34 PM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It could be a simple misalignment of the front subframe. Do you know if the subframe bolt were changed on it?
If the caster is misaligned one wheel will want to pull against the other and push the car in one direction. You would not see any abnormal wear on your tires if toe and camber are correct.
But it could also be a misalignment of the rear axle, tracking to the left. (Dog tracking)
Old 09-08-2015, 10:35 PM   #6
CoryM
Drives: 2009 5-door, 5-speed
Experienced alignment guy here. Step one is to swap your front tires from L to R and try it again. If it leads the other way (or just changes) it's time for new tires. Most leads, unless you have hit something, are caused by tires. If you don't notice a difference, then it's time for an alignment check. Leads are caused by camber/caster angles (or setback). If the angles are not even enough L to R (typically around 0.5°) you will get leads. It's also possible it's brake drag on one side, but you'd probably notice other symptoms of that by now.
Cheers.
Old 09-08-2015, 11:00 PM   #7
attrapereves
Cheers.
I've owned my car since January and new tires were on it when I bought it. It's got 75K miles on it, but I've only put about 6000mi on it. I'm getting the tires rotated soon. I'll see if that helps. If not, I'll get it aligned.
I can't remember if it pulled to one side when I bought it.
Old 09-17-2015, 07:57 PM   #8
attrapereves
Took the car in for an alignment today. The car was still in alignment, but a tire rotation seemed to fix the pulling issue. I guess I should have just got the tires rotated first.
Why would tires with only 6000mi on them cause pulling like this?
Old 09-17-2015, 08:03 PM   #9
Bluevitz-rs
Did you check tire pressures? A tire's tread can cause this also if the pattern isn't in line cause it to want to walk in one direction.
Old 09-18-2015, 06:47 PM   #10
attrapereves
Yup. Pressure is good.
Old 09-18-2015, 11:36 PM   #11
CoryM
Darn. If only someone had suggested that..............
Tires can be bad out of the factory. They can also be damaged from impacts, driving with low pressures, sitting still for long periods, etc. Occasionally a tire pull will not get worse, but often it is indicative of a separation which will worsen (or fail). What brand of tire are they? Cheaper tires are far more likely to have leads and balance issues.
Cheers.
Old 09-17-2015, 08:38 PM   #12
bgkz25
bgkz25's Avatar
Drives: 2006 Toyota Vitz 1.5Li
Eventhough tires are new, it's the tire conicity that causes these side-pulling problems.
http://www.agcoauto.com/content/news/p2_articleid/181
Sent from my SM-N9005 using Tapatalk
bgkz25 is offline   Reply With Quote
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
