Old 09-15-2015, 04:52 PM   #1
ucsmfu
Drives: yaris le
Disable DRL on 2012 Yaris Le
Just wondering if anyone has come across disabling their DRL on 2012 yaris le.
I have the Canadian model, so we have 1 dual H4 filament bulb that serves as DRL, low beam, and High beam.
I have done a projector retrofit in them and it's running H1 hids and with a H4 relay it's pretty much running the whole time.
Was wanting to disable the HIDs during DRL and then have them come on when I turn on the headlights.
If anyone has any ideas of inputs please let me know
ucsmfu is offline   Reply With Quote
Old 09-15-2015, 07:05 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
DRL box under driver side dash by the steering column just unplug it
Old 09-15-2015, 08:43 PM   #3
Not on a 3rd gen. On it the DRL control is integrated into the body ECU and the relay it controls is within the 2nd under-hood fuse panel.
Old 09-15-2015, 09:21 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Yup, did not even see the yr in post lol
Sent from my SM-G900W8 using Tapatalk
Old 09-15-2015, 11:56 PM   #5
ucsmfu
Drives: yaris le
hello Scott,
so just remove the 2nd under-hood fuse and I should be good ?
Thanks
Old 09-16-2015, 07:09 AM   #6
Originally Posted by ucsmfu View Post
hello Scott,
Thanks
No. It is far too integrated for a simple solution.
Old 09-16-2015, 02:49 PM   #7
ucsmfu
Drives: yaris le
Would you recommend that I don't disable DRL, what other options do I have ?
Right now my Hids are running all day, as drl and as headlights :/
Old 09-16-2015, 11:28 AM   #8
edmscan
edmscan's Avatar
Drives: 2020 Corolla
You do realize that in Canada .. it is illegal to disable your DRL's.
Not only illegal but really .. stupid as studies have shown that driving with them is very much safer.
edmscan is offline   Reply With Quote
Old 09-16-2015, 02:44 PM   #9
ucsmfu
Drives: yaris le
hey, yeah I know it's illegal, but I am planning to run the fogs as drl.
and I don't want the HIDS running 24/7 that's why if I can diable drl, run fogs and than evening time I can switch hids back on.
Old 09-16-2015, 11:29 AM   #10
IllusionX
Drives: 07 Yaris Sedan Aero
I think it would be easier to reroute the headlights wires to a LED strip for DRL, and change stalk switch to activate a nee relay connected to the battery and have new wiring done for the headlights.
Sent from my A0001 using Tapatalk
Old 09-16-2015, 02:48 PM   #11
ucsmfu
Drives: yaris le
I tried adding a led strip in the headlights but I don't really like the look of it ><
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 09:08 PM
What is it about the Yaris Ranger SVO General Yaris / Vitz Discussion 18 01-06-2015 10:45 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
