Old 09-26-2015, 09:03 PM   #1
redyaris2012
Drives: 2012 yaris sedan
Synthetic Gear Oil
After 23,000 km, decided to replace the factory gear oil on my 2012 5 speed manual with synthetic Royal Purple. Expensive for 2 bottles each at 946 ml but if it performs better and is more efficient, than it justifies the cost. Well, after a few days of driving, I have noticed shifting is smoother and changing from 2nd to 1st is really smooth. Convinced to always use synthetic. The manual only states changing gear oil only under extreme conditions. My 1980 Corolla had 285,00km and I never changed the gear oil and the 4 speed transmission never failed.
2012 Toyota Yaris
2001 Subaru Forester
redyaris2012 is offline   Reply With Quote
Old 09-26-2015, 11:44 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Gear oil should be changed every 65000km. That includes AWD differentials.
But then, if it works for you. I switched to Castrol Syntec 75w90 and it was the worse mistake I did. Synchros would grind under high rpm shifting.
I briefly used RP synchromesh, and it helped, but still wasn't good, so now I have AmsOIL 75w90 and its working as it should. Still grinds from time to time, but that's probably because my synchro are already damaged...
Sent from my A0001 using Tapatalk
Old 09-28-2015, 04:21 PM   #3
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I'm using Red Line synthetic in my trans. I recently noticed a slight occasional grinding going from 1st to 2nd, but I don't know of the two things coincide.
Old 09-28-2015, 09:07 PM   #4
CoryM
Drives: 2009 5-door, 5-speed
I suggest running the OE specification for A/T and M/T. The reason being you have friction surfaces which are designed to work with a certain fluid. If you make that fluid more or less slippery, the friction surfaces will increase or reduce their performance.
In the case of M/Ts, you have synchronizer rings. These are little brakes that use friction to slow the spinning parts down enough that you can change gears without grinding. If you use slippery synthetic oils the syncronizers will not work as well; making it take longer to slow the rotating parts down.
I tried two different synth oils in my Yaris since the shift feel is so bad, and because I'd heard a lot of people on the forum have positive results. I ended up going back to non-synth oil within a few days because I could feel the syncronizers not working as well. The generally accepted life of uncontaminated gear oil is 100,000km to infinity (many OEM suggest there is no need to change). That being said, I have never personally done oil analyses on gear oil.
Old 10-01-2015, 01:17 PM   #5
Frank Necrosis
Drives: 2012 Yaris L MT
After putting 15,000 miles on the car, I switched to Redline in hopes of improving the shifting. It helped for a while, but after about 10,000 miles, the shifts were worse than ever. When I drained it, it was like water coming out of the case. The Redline seemed to break down in spectacular fashion.
I ran Mobile 1 for about 30,000 miles and it did ok. Mobile 1 was nice during the sub 0 degree F temps we had last winter. The trans would go into gear without much of a fight before it warmed up. Over the summer, the shifting became difficult again, so I swapped out the Mobile 1 for Lucas. Mobile 1 wasn't in stock, and Lucas seems to make good products. So far so good.
Frank Necrosis is offline   Reply With Quote
Old 10-05-2015, 08:09 PM   #6
Thirty-Nine
I'm using the right spec: 75W90 GL-4, although it is synthetic. I am noticing a slight grind during the 3-2 downshift (no where else). Never noticed it before. Hmm ...
Old 10-05-2015, 11:59 PM   #7
SirDigby
Drives: 2007 yaris 3 door
that's strange. I've never heard of such things. I was going to change my m/t fluid soon. I've always had Hondas before, which use their own fluid; synthetic I believe. no quality aftermarkets available that I know of. i'm going to do a little more research now....
Old 10-06-2015, 12:04 AM   #8
IllusionX
I've never had issues with down shifts. Maybe because I always double clutch my downshifts. But I could grind 3-4 and 4-5 upshifts at high RPM with the synthetic oil.
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 09:43 PM
Synthetic VS. Regular oil reliability captainm27 DIY / Maintenance / Service 98 01-20-2010 02:46 PM
Synthetic Oil Questions. Twistoffate0817 General Yaris / Vitz Discussion 19 07-15-2009 09:54 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 04:40 PM
