Old 11-14-2015, 09:15 PM   #1
A115
Drives: Yaris
Revs but no acceleration?
My girlfriend and I have a 2009 Yaris that is having some issues. Today, we went to start it but it stalled out on the first start. After another attempt, started fine. When we hit the highway, the car maxed out at 35 miles per hour and the engine was revving at high rpm. I am guessing that there is a transmission issue here, but I have no idea how to proceed.
Any ideas on what could be causing issues?
A115 is offline   Reply With Quote
Old 11-14-2015, 09:37 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
need more info , age km on car etc
Old 11-14-2015, 10:11 PM   #3
A115
Drives: Yaris
Sorry!
2009 Yaris, 65k miles
Old 11-15-2015, 09:25 AM   #4
So we are talking about an automatic transmission I gather. Sounds like it is not getting out of first gear. Have you tried manually shifting it? 1 - 2 - 3 - D to see if you can make it change gears.
Old 11-15-2015, 09:57 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Or a shift solenoid failure
Old 11-15-2015, 02:21 PM   #6
A115
Drives: Yaris
It is automatic. I did try to manually shift it isn't making any difference.
Not sure about a shift solenoid. It's possible.
Old 11-16-2015, 01:13 AM   #7
bail_w
Drives: 2007 Toyota Yaris LB
Check the transmission fluid? Perhaps, replace the fluid if never done before?
bail_w is offline   Reply With Quote
Old 11-19-2015, 08:47 PM   #8
maralieus
Drives: 2007 toyota yaris s
Sounds like your car is in limp mode. If there is something wrong that can cause damage it will force "limp mode" to get you home without destroying more parts. My old Mitsubishi did the same thing. Could be wrong but it could help your search Idk.
maralieus is offline   Reply With Quote
Toyota Recalls auxmike General Yaris / Vitz Discussion 535 02-25-2021 07:13 PM
weird revs? toad DIY / Maintenance / Service 4 04-29-2015 10:42 AM
Yaris acceleration problem myahya UK 3 04-01-2012 06:38 PM
Toyota Vitz 2006 automatic - engine revs lot thea500 General Yaris / Vitz Discussion 0 11-24-2010 03:05 PM
Did Toyota Prius Driver Fake Unintended Acceleration? JBougie Off-topic / Other Cars / Everything else Discussions 33 03-15-2010 12:24 PM
