Our lord and Neigh'vior.
Drives: . Join Date: Oct 2015
Vehicle: 2008 2d Hatchback Yaris
Okay, so I replaced a tail light cover (Last one was shot by a BB-gun) and it began a massive cascade of issues... The signal lights worked for a moment before buzzing on and off and have since them been non functional. Battery light comes on (flickering) Airbag light is on, heater lighter is on (Even though its not in use) Fan doesn't work. Signal lights aren't working. Gearing status (Drive, parked, etc) will not show when attempting to use signals or breaking. Horn, break lights, Headlights, backup lights work. Interior dome light works. Emergancy lights will flash and click (working relays). Tried replacing the car battery since the battery light was on and the current one was 7 years old anyways and the issues remain. We've checked the fuses, the break light bulbs were replaced (as they stopped working after the tail light cover and work now.) and I've no money to take it in and get it looked at. (Unemployment sucks, I'm not bringing in enough to support myself where I live anyways.) Any suggestions on what is wrong? Thank you for your time. Also, first post! |
Sounds like you popped one of the fusible links, which are built into the positive battery terminal.
On the black plastic block (under the red cover) on the positive terminal there are two fusible links.
How did you check them?
In the fusebox, they were removed and tested with a wigi back when were were trying to figure out what precisely had gone wrong. With the battery, I gave a careful look (since I dont have my own multimeter at this time) and didnt see any scoring or breaks up top via visual inspection. Perhaps I should remove them and use a wigi?
#8 | |
#9 | |
So I took it to the dealership, hopefully it wont cost too much to repair, I'll leave what was wrong with it when I get my call on when they figure out whats wrong. Update: Results are in. Pinched wires. they're being resoldered in. $200 USD on Nov 20, 2015 Thank you for your help, CTScott. <3 Last edited by NoisyPegasus; 11-20-2015 at 01:17 PM. |
| Tags |
| signaling issue, yaris |
| Toyota Recalls | auxmike | General Yaris / Vitz Discussion | 535 | 02-25-2021 07:13 PM |
| Steering Wheel Jams, Battery Warning Light flickers, Starting Issues | tmrtza | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 10-31-2014 10:01 PM |
| Just bought a 2010 Hatchback AT and having some issues | Dissolutus | New YARIS Purchase Forum | 9 | 03-19-2010 11:46 PM |
| CV joints or axel issues | aucorium | DIY / Maintenance / Service | 1 | 02-17-2010 10:10 PM |
| For the TEIN S tech users any sagging issues? | marcus | Performance Modifications | 7 | 01-28-2010 05:06 PM |
