![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
Stupid Seatbelt!
this stupid seatbelt is pissing me off!
does anyone know if there is a way to adjust this thing so it stops rubbing on my neck? I have a hard time believing that this is the position small Asians prefer to have their seatbelts, it'd be rubbing on their foreheads. are they repositioned for the USDM? gurr!!! |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
where the belt attaches to post by your head it can be adjusted down. squeeze and pull down
what? your crazy. don't you think that's the first thing I looked for...
I can't believe there is not an adjuster... |
Mine has one.
Correction: my wifes CAMRY has one. Mine does not.
Synthetic Oil: Its All In Your Head Last edited by bronsin; 12-06-2015 at 08:22 AM. |
Post a pick of your b- pillar attachment point. Nobody is going to believe you don't have an adjuster.
#6 | |
here's angle #2 do you think I can find a pivoting one in the junk yard? have you had your b-pillar off? do you know how the adjuster is attached? I guess I could go pull it apart and check it out.... |
The service manual shows that all sedans and 5 door liftbacks have the adjustable ones and 3 door liftbacks do not. The B pillar cover area is different one 3 vs 5 door, so you wouldn't be able to grab a 5 door one to use to convert.
Wow, didn't realize that about the 3dr. How ludicrous not to have incorporated an adjuster.
I'm sure plenty of 3dr owners read this thread and never bothered to respond. That's a YW fail for sure.
Owning a 3 door myself, I dismissed the comment about the adjuster because I had no idea any model had them. Thought the guy that posted that was confused lol. Never dreamed they'd make the 3 door different in that regard.
Having owned an "07 3-door until just a week ago, I never felt the need to adjust the seatbelt and just assumed all models had no height adjustment.
I wonder if my '14 5-door has a height adjuster? I'll have to check later. |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
i'm taller that the average Asian. I don't understand why it's so high. i'm going to have to pull it apart and see if I can weld a different mount in to drop this thing like 3 inches. it can't be good to crash and have this thing rip my neck open...
#14 | |
You may be able to simply obtain the adjustable anchor (73200-52050-B1) and it's cover (73135-52020-B1) and cut the hole in your B pillar cover to let it slide up and down: Yaris - Seatbelt adjuster.jpg
| My seatbelt alarm won't shut off. | JohnBeske | DIY / Maintenance / Service | 1 | 08-01-2014 09:42 PM |
| Rear seatbelt buzzer? | brendan | Third Gen Yaris General Discussion | 0 | 07-19-2013 06:26 AM |
| Takata Racing Seatbelt | 33lam | Australia | 0 | 09-02-2010 08:41 AM |
| Two stupid questions.... very stupid... | Blowtorch | General Yaris / Vitz Discussion | 26 | 05-08-2009 12:06 AM |
| Seatbelt warning annoyance! | asa805 | General Yaris / Vitz Discussion | 5 | 06-30-2006 07:06 PM |
