![]() ![]() ![]() ![]() ![]() Drives: 2016 SE Join Date: Nov 2015
mis-aligned steering wheel
The car is 3 weeks old with only 150 miles
I'd guess it's ~2-3 degrees to the left when driving on any smooth, flat road none of my other cars are this way anyone know what the spec/ allowed deviation from center is? I expect the dealer mechanic to say it's normal drives me nuts! ![]()
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
That looks significantly off to me. No way the dealer can claim it as "normal".
Not to be rude but did you not notice this when you test drove the car? |
Oh, man, that would tap into my OCD like no other.
Definitely not normal.
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Best case scenario, you just need an alignment. Have you gone over any deep potholes lately? How about bumps or dips at an angle? Any weird noises heard in the first 150 miles?
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
Alignment is covered under warranty for up to 15k so drive down and have it done
Sent from my SM-N910W8 using Tapatalk |
no pot holes/ curbs hit - didn't notice since the car has barely been driven
the car drives perfectly straight just the steering wheel not aligned properly to the dealer tomorrow |
#8 | |
![]() ![]() Drives: Toyota Yaris 2015 1.0VVT-i T2 Join Date: Jun 2012
But on friday they are going to put on some fog lights and I hope they will address the steering also.
Toyota Yaris 1.0VVT-i T2
![]() ![]() Drives: Toyota Yaris 1.33 SR Join Date: Nov 2014
My car used to have the same problem when it was lowered on Eibach Pro Kits. I found out that it was due to the mechanic that didn't re-clock the bushings after installing the springs!
Successfully fixed by the dealer
The Tech said the spec for steering wheel center is +/- 3 degrees mine was -8 degrees to the left it has now been optimized and is perfect
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY - Converting a 2nd gen Yaris to the best part of a 3rd gen (Steering wheel audio) | CTScott | DIY / Maintenance / Service | 12 | 01-22-2022 03:09 AM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 10:16 AM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
