![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
Hissing Noise
Hi All
I am listening a strange hissing noise from driver side inside car. it only happen when I am driving on speed. can anyone help;. |
Don't drive while on speed. Drugs are bad for you.
![]() ![]() Drives: Hatch Join Date: May 2009
Maybe you are scaring your snake.
Thts no solution chaps
Sent from my GT-I9195 using Tapatalk |
I guess the question draws out the humor in some of us.
This is kind of a tough one. Some cars have vacuum hoses under the dash. Did you investigate under the dash? Maybe a loose vacuum hose? Any sign or odor of coolant? Have you tried various settings of the air flow control? Are you certain it is inside the car? Sometimes tires can make strange noises on certain pavement at certain speeds. Is your tire wear even? You might need to take it to a dealer and have someone ride with you and listen to it. |
If it's only at speed then it's likely not a vacuum issue but more of a tire or wind issue. Use a diagnostic reader to check fuel trims and what not. This will rule out anything somewhat serious.
Post a video. ..that may help more than words alone.
| Compilation of Yaris TSBs | eTiMaGo | DIY / Maintenance / Service | 72 | 07-04-2024 11:36 AM |
| Colour Collection 05 Reg (UK) brake noise | JLx | DIY / Maintenance / Service | 0 | 07-14-2015 07:56 AM |
| metallic noise when accelerating | poida | DIY / Maintenance / Service | 3 | 03-29-2015 01:20 AM |
| Help With Reverse Noise???? | JoshW | DIY / Maintenance / Service | 0 | 09-09-2011 01:27 PM |
| Radio noise.. need help | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 12-06-2008 05:21 PM |
