![]() Drives: Toyota Vitz Join Date: Oct 2015
Should I follow recommended tyre pressure?
My car is Toyota Vitz (Yaris for Japanese market). It has stock tyres which is 165/70R14 81S. The recommend tyre pressure according to door sticker is Front: 250 Rear: 240. As our local tyre shops inflate tyre at PSI gauge so I collected user manual of this car and found that the recommendation in PSI is Front: 36 Rear: 35. But when I went to the local tyre shop to inflate the tyres and asked to inflate as per car recommendation the attendant said higher PSI in front tyres will make the car jump. So he inflated Front: 32 Rear: 35.
Same goes to the spare tyre. Its size is T125/70D16 95M and recommended is 60 PSI but the attendant put 40 PSI. So should I hear that local tyre shop or do as recommendation? *a supplementary question: My main tyres size is R14 but spare tyre is D16. This spare tyre was not included with the car, it was kind of a gift from the seller. On the manual I saw that the spare tyre size for this car is D15. So should I change the spare immediately? |
I would keep the pressure according to Toyota.
No understanding of the spare tire problem...
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
On these cars, that factory recommendation is about right for most people's driving to get the best tire wear. You won't see any "jumping" from running those pressures.
Spare tire should be set to it's maximum pressure. Spare tire outside diameter should be the same as the tires you have on the car now. That's all that matters. |
#4 | |
Will it destroy the differential?
No, it's more of a safety issue. The walls on spare tires are really thin. If you are ever in a position to make quick turns to dodge something, the spare tire is likely to pull off the rim or will just blow. Also, you want most of your car control in the steering. Having that flimsy tire up front is just not a good idea.
also, you will notice the tread patter on the spare tire doesnt have much on the shoulder of the tire. Not good for turning. Spare tire will last longer if you just put it in the rear.
#7 | |
There's a vid on utube of Chris Harris drifting a AMG Mercedes with 4 of them on. |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
dude its a front wheel drive...front wheel tire pressure should be higher 😂😂😂😂
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
LOL, calm it down. You got to put the fear of god in people for them to listen
we got Gran Turismo player in this forum..lol 😂😂😂😂
| Questioning the Recommended Tyre Widths based on Offset | Energiser | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 02-24-2012 10:32 AM |
| What tyre pressure? | whoguy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 12-29-2011 09:00 AM |
| screw more psi in the tires. | thebarber | Fuel Economy Forum | 43 | 05-04-2009 04:46 PM |
