![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
1NZ Supercharger Info please
can somebody give me detail on blitz supercharger...is it worth it? reliability?
hp gain? right now i have pair of bolt on camshaft being manufactured at the plant but also thinking about getting supercharger instead...pair of bolt on camshaft will gain 18hp(theyre dyno sheet from stock 1nz)...😎 im thinking i should save a little bit more money and go for supercharger... any opinion? http://cloud.tapatalk.com/s/57cba049...04-111632.png? Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
I want to SC, but I want to go with rotrex. I believe the boost on the blitz does not kick in until 3k rpm and if it's going to lag, you should just go with turbo. the rotrex boosts much lower, and has a planetary gearset making it work kind of like a automatic transmission instead of like a power drill. they also achieve a higher efficiently rating than a turbo, (the only SC that does) and run MUCH cooler temps.
http://www.rotrex.com/Home/Technology/Product_Concept they also have an electric assist that looks VERY promising! |
^^^NOTE: they are pretty damn expensive....
im on a tight budget..virgin pussy tight budget...theyre way too expensive yo... 😂😂😂😂
well, that doesn't make much sense if you're having custom camshafts made and you are talking about modifying the way your engine functions. just the camshafts and the time to shim the buckets is over $1000. any SC is going to cost +$1300 you will need engine management, +$1000 (idk what it takes for E85, you might already have EM) I don't think you should "build on a budget," you should build what you want, IMO.
#6 | |
I got 30whp and 25wtq on my 5 speed 2007 yaris
thats good amount of power gain...☻☻☻☻
for the budget power, coupled with high octane e85, you could go nitrous. you could safely push 30-50hp, maybe 20 or 30 more if you dare. the setup would only cost like $700...
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
I've actually been trying to get rid of my old Blitz supercharger for a while now. Was gonna let it go for 1k. It's got a fixed pulley but it worked great on my car.
#11 | |
Drives: yaris 4dr hatch Join Date: Aug 2016
r u still selling ur blitz?
| List of Boosted Yarisworld Members | whooppee777 | Forced Induction Forum | 262 | 11-23-2022 05:49 AM |
| Blitz Supercharger Wiring Question | KTS | Forced Induction Forum | 29 | 09-06-2015 04:45 PM |
| Custom Supercharger Possibility??? | alias06 | Forced Induction Forum | 3 | 03-19-2015 10:39 PM |
| What real gains from supercharger? | xb visitor | Performance Modifications | 9 | 07-30-2014 08:46 AM |
