uk hardcore for life
Drives: toyota yaris 2008 sedan Join Date: Jul 2010
2008 Yaris ac system
Hey guy, last week i have made at dealership a decontamination of the ac system and refill , the ac have worked 15 minute and now it's blow again hot air
, i have call the stealership but it's charge me max 2 hour to make a new diagnostic wich it's 275 $ cad , do you have any idea what the problem can be ? Last week he have make the refill and check for leak, i got no leak. ![]() Thanks |
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
Make them accept the cost, as the job you paid them for didn't work for long.
Sent from my LG-D801 using Tapatalk |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
A/C
on a 2008 yr old model maybe the condenser is really dirty, check that. Does your engines electric fan come on when you turn the A/C on ?
You can't have cold A/C if the condenser is not getting air flow through it. You know how to read/use manifold gauges? hook those up and see what the low and high pressures are before and after you turn on the A/C. with A/C off both low and high pressures should be equalize and should be around 90-100 psi. when the A/c is turned on the low comes down to about 30-40 psi and the high go's to about 150-175psi. depending on ambient temperature. |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 09:02 AM |
| 2008 Toyota Yaris passenger side view mirror change | KOOCHO | DIY / Maintenance / Service | 1 | 12-01-2012 10:52 PM |
| Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c | Yar Is Word | Third Gen Yaris General Discussion | 27 | 09-07-2012 12:37 AM |
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 10:34 PM |
