Old 03-31-2016, 04:12 AM   #1
sang pengembara
sang pengembara's Avatar
Drives: Y-sedan'07-1nzfe engine swap
prius piston fit yaris (what is part number)?
Please help, I need part number of prius piston and ring sets fit yaris 2008. Found from other thread was:
Rings:
1NZ-FE: 13011-21041
1NZ-FXE: 13011-21100
Pistons:
1NZ-FE: 13101-21070
1NZ-FXE: 13101-21110
thank you
sang pengembara is offline   Reply With Quote
Old 04-03-2016, 09:32 PM   #2
Dragonslayer182
Teal Squealer
Drives: 07 Yaris Sedan
They most likely will not work. The Yaris engine has a different compression ratio than the Prius.
Dragonslayer182 is offline   Reply With Quote
Old 04-03-2016, 09:40 PM   #3
Those part numbers are correct and they will fit. They will result in a higher compression ratio, but I assume that is why you are looking for them.
Old 04-03-2016, 09:44 PM   #4
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Prius piston Swap
Those part numbers should be good. Those are the part numbers from a 2008 prius.
brushforhire is offline   Reply With Quote
Old 04-04-2016, 12:53 AM   #5
LTHatch
Drives: 2013 Yaris Hatchback L
Does the prius pistons swap include the prius rings as well? They yaris and prius rings face different stresses, curious if the yaris rings might be a better option with the prius pistons.
LTHatch is offline   Reply With Quote
Old 04-04-2016, 05:19 AM   #6
sang pengembara
I place an order and waiting for the material to be shifted from state.. 4 pcs of prius piston including the rings.. I will update with pictures when the work is in progress.. ��.. it will be direct bolt on to the stock of 1nzfe..
Sent from my C6903 using Tapatalk
Old 04-04-2016, 11:27 AM   #7
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Prius rings are thinner than Yaris rings, they also have less tension. Everything should work, but you need extremely high octane fuel to compensate for the extra compression. You also won't be able to modify the cams as there is less clearance for lift and duration.
2014 BSpec Divisional Champion
Old 04-05-2016, 06:05 AM   #8
sang pengembara
Here in Kingdom we have 92 and 95 octane available, I hope it will run the engine properly..
Old 04-05-2016, 06:51 PM   #9
xnamerxx
0-60 in slow
xnamerxx's Avatar
You'll probably have to run 95, I wouldn't think 92 would cut it.
Old 05-24-2016, 04:33 PM   #10
sang pengembara
The Pistons just arrive... 😀 feeling happy...
Old 05-24-2016, 04:41 PM   #11
sang pengembara
I hope there is some slots to install this Pistons ASAP...
Old 06-11-2016, 02:51 AM   #12
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
please update for us...did you install them yet? i heard you also need new set of piston rings...updateeeeeeeee 😬😬😬😬😬😬
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 06-11-2016, 03:36 AM   #13
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
show us dyno results xD
Fluxtasy is offline   Reply With Quote
Old 06-11-2016, 09:14 AM   #14
eneos_86
Drives: vios
Hi... I from malaysia... that piston can handle standard connecting rod... I very interested about that modified
eneos_86 is offline   Reply With Quote
Old 07-25-2016, 03:27 AM   #15
TRD SPEC
TRD SPEC's Avatar
Drives: Ncp42
Can't wait to see the dyno and more info about it.
Sent from my 3006 using Tapatalk
TRD SPEC is offline   Reply With Quote
Old 07-25-2016, 03:31 AM   #16
rabbito
rabbito's Avatar
change of plan.. bolt on racing cam...about the same price...rather go cams than piston
Old 07-25-2016, 03:33 AM   #17
TRD SPEC
TRD SPEC's Avatar
Drives: Ncp42
Wut...... awwwww
but still with higher lift cam doesn't that make it more power to the mid and high range and less on the low?if you doesn't upgrade the compression i don't think the car would accelerate well unless you hit top speed alot...
Old 07-25-2016, 03:39 AM   #18
rabbito
rabbito's Avatar
i was trying to buy the prius pistons from the dealer and pay for the labor but most of shops were annoyed by it. they were trying to sell forged racing pistons that had similar cut out as prius pistons..😡😡😡😡😡
so i decided to go for the cams...hassle free...pay and install kind of thing...😃😃😃😃
but im still keeping this project..
Power-to-Weight Ratios of Yaris, Fit, Mini, etc. Idjiit Off-topic / Other Cars / Everything else Discussions 6 10-06-2017 06:10 PM
test drove a fit...mirage...and a yaris 428CobraJet Third Gen Yaris General Discussion 15 05-17-2015 03:08 PM
On tire pressures, the Yaris, and the Prius sbergman27 Fuel Economy Forum 18 04-05-2010 06:35 PM
