Old 07-07-2016, 05:01 PM   #1
edmscan
edmscan's Avatar
Drives: 2020 Corolla
Scheduled service at 196,000 km / 118,000 miles
I have a 2007 Yaris and want to query the car guys here. I am not a car guy in the slightest.
edmscan is offline   Reply With Quote
Old 07-07-2016, 11:01 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
09TO7BX01-DPF Cabin Air Filter
Replace every 24000KM, or when dirty. You can probably do this yourself. Do a search.
12TO7BX02-CF SLL4 Coolant Re - Apparently due now.
Should be done every 5yrs to ensure the coolant doesn't start eating gaskets.
15TO7BX-TF M64 Trans Fluid - Apparently due now.
A/T every 50,000, M/T every 100,000
13TO7BX082-FIS Fuel Injection - Due at 208,000 km
Never. If you are using top-tier gas this never needs to be done on a Yaris.
18TO7BX-BS Brake Service - Rear brakes never done, Front in 2011
Rear brake service should be done every 24,000km and they should be adjusted every oil service (I adjust for no-charge for all my customers). Rear brake adjust is important because otherwise your front brakes do all the work. Front brakes are kind of a toss up whether it is cost effective to service them every 24k or not. It's certainly not a bad idea, and can save you money if your caliper pins get sticky.
18TO7BXCBF-048 Replace Brake F - Done in March 2012
If they are due, they are due.
Hope this helps.
Old 07-08-2016, 10:53 AM   #3
Tapokata
Drives: 2009 Yaris
Per the owner's manual, coolant should be changed out at 100K miles for the factory fill, and at 50K mile intervals thereafter. There's no time limit stated, although it would be a concern if the vehicle is parked for a significant period.
Fuel injection service is a means for the garage owner to make a boat payment. It shouldn't be needed.
Tapokata is offline   Reply With Quote
Old 07-10-2016, 01:59 PM   #4
SirDigby
Drives: 2007 yaris 3 door
I like using bg products. i'd recommend using a can of BG 44k at a fill-up sometime...
Service intervals Yaris175 UK 3 11-18-2014 06:26 AM
I hate cable service providers. Altitude Off-topic / Other Cars / Everything else Discussions 27 09-12-2010 09:09 AM
I don't know why but my area my customer never appreciate good service YarisSedan Off-topic / Other Cars / Everything else Discussions 12 02-27-2009 10:26 AM
Funny Business at the Toyota Service Centre *MAD DOG* DIY / Maintenance / Service 10 01-10-2009 12:47 AM
Metro Atlanta Dealer Service Experiences redyaris Southeast 2 03-21-2007 03:59 PM
