Old 09-19-2016, 04:23 PM   #1
Jesper M
Jesper M
Drives: Toyota Yaris Verso 1.3
Direct battery connection - how can it be done?
Hi Toyota Yaris forumers,
I have a possibly simple question that I hope one of you may know about ...
As it is I would like to connect a cooling box directly to my Yaris Verso's battery (will make sure a low bat circuitry protects the battery), however, would appreciate an advice on how a cable can suitably be guided from the battery into the cabin in a simple and preferably non destructive way (i.e. very preferably no drilling). Might one of you have a suggestion for a simple and straightforward way of doing this?
Thanks for any help
Jesper
Jesper M is offline   Reply With Quote
Old 09-19-2016, 06:39 PM   #2
bronsin
bronsin's Avatar
Why dont you want a battery heater living so far north?
Old 09-20-2016, 03:47 AM   #3
Jesper M
Jesper M
Well, that's not what I need & I don't think it's necessary - the car appears to always start even when the battery is very low on energy (which would be the case if the battery is very cold) ...
Jesper
Old 09-20-2016, 06:50 AM   #4
bronsin
bronsin's Avatar
Can you describe again in other words what you (adwant to do because I don't understand.
Old 09-20-2016, 09:39 AM   #5
My take on this is that he wants to direct connect something like this
Old 09-21-2016, 03:02 AM   #6
Jesper M
Jesper M
Hi WeeYari,
Yes you are exactly right - and I would like to mount a cable directly on the battery and lead it into the cabin preferably without drilling any holes ... might you have any ideas?
Cheers,
Jesper
Old 09-21-2016, 03:13 AM   #7
Jesper M
Jesper M
Hmmm... guessing that the "ceiling - light" sockets somehow could be used as they are not switched on/off when the car otherwise is switched off ... But I don't know what the power rating of the wires going to these lights are ... Anyone knows?
Cheers,
Jesper
Old 09-21-2016, 09:36 AM   #8
Somewhere there has got to be a rubber grommet in your firewall through which wiring is already fed. Just matter of finding it and fishing your wiring through it.
Old 09-21-2016, 11:44 AM   #9
bronsin
bronsin's Avatar
RIGHT BEHIND THE COMPUTER on the right hand side of the firewall is good...on my 09.
Old 09-21-2016, 02:36 PM   #10
Jesper M
Jesper M
@bronsin & WeeYari ... Thanks for your suggestions. I will look after the grommet and in general holes in the firewall. Mine is a 1999/2000 so it may not be identical to a 09 or 06 but will see what looks feasible.
Cheers,
Jesper
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Remote for remote starter draining its own battery. bad DIY / Maintenance / Service 4 11-01-2015 02:00 PM
Battery keeps going dead Outdoorsman In Car Entertainment + Electronics (audio / video / alarm) 6 09-09-2013 05:43 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 10:34 PM
