Drives: 2008 Yaris Sedan Join Date: Aug 2016
New brakes, squeak sound at front brakes
Hi guys, 1st post ever on Yarisworld, such a bible in here, amazing !
Still writing for a squeak sound my girlfriend's getting with her front brakes (new rotors & pads, 500km on them) on a 2008 Yaris. https://youtu.be/BF5zBAvQPTU The video tape was took from the outside near the driver side wheel almost at stop position. Sound at 6 and 8 sec is the brake paddle itself. You hear it only when releasing very gently the brake pedal from a stop position or when making a complete stop with pedal to the floor, normal brake application doesn't really make the sound, but still annoying and I'd like to find where it's coming from. Rear drums were cleaned and greased also, they were making their own squeak sound, but cleaning and greasing them solved the problem. I did the brake job myself, dissembled the whole thing a 2nd time and still getting the same sound...any idea ? Thank you ! |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
my stock pads were like that...changed them to racing pads...no sounds at all other than when i start the car in the morning and leave home...pads and rotors are just starting to warm up..sounds normal for me..and it goes away in a minute..
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
Sometimes brake squeak is just the way it is. What brand rotors and pads did you use? Also, did you go through with the exercise of bedding in the brakes after you replaced them?
![]() ![]() ![]() Drives: 2013 Yaris Hatchback L Join Date: May 2013
My stock Yaris brakes make the same sound at very light braking, especially when they are cold. Did you get the new rotors nice and warm and try to see if it made the same noise?
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 06:35 PM |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 10:03 AM |
| **SAFETY RECALL!! 06-07 YARIS HB & SEDANS** | slvryaris | DIY / Maintenance / Service | 83 | 09-30-2012 01:25 PM |
| New Sound System - Sound Issues | click.mine | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 03-20-2009 04:11 AM |
| Coilovers - creaking sound from passenger front? | Gideon | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 03-16-2009 04:20 PM |
