Old 10-12-2016, 12:34 PM   #1
aaron21339
Drives: 2009 5 Door Automatic
New Serptine Belt Squealing
Hi all, I recently purchased a 09 5door with 96,000 miles on it. I had the serpentine belt changed about two weeks ago. The next day it started squealing when I started the car, and when I first start driving for a minute. I've tried turning off the air conditioning like i read about but it didn't help any (the battery is a year old).
I took it back to the mechanic a week ago. He said he looked at it, there was no problem with anything, it's just new and it might take a month to stop squealing.
It hasn't been a month but the belt is still just as bad sounding, what would you guys suggest doing?
Thank you!
aaron21339 is offline   Reply With Quote
Old 10-12-2016, 12:37 PM   #2
Increase the tension. All belts stretch and are often in need of re-tensioning shortly after install.
Old 10-12-2016, 07:12 PM   #3
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
^yup just increase the tension by adjusting the alternator position.
Old 10-13-2016, 12:04 AM   #4
Maddiesyardstick
Drives: 2012 blue 4 door hatchback yar
My 2012 does this every so often. A/C tends to make it louder in my car but it's a simple fix. It just needs to be tightened.
Maddiesyardstick is offline   Reply With Quote
Old 10-13-2016, 03:14 AM   #5
jcboy
Drives: Sedan 07
Agree with all. Manual says inspect every 20,000km.
And thanks YW (and those who posted on another topic) i changed mine after 80,000km even if it looked fine. ( some mini cracks on the grooves but generally fine)
Saved a few bucks by using yarisworld, a 3/8" drive ratchet (1/2" ones have too long sockets) and a pipe.
Sent from my G9208SS using Tapatalk
Old 10-13-2016, 04:19 PM   #6
aaron21339
Thanks for the replies guys, could you guys dumb down how to tighten the belt? I've found a few things buy am pretty amateur when it comes to under the hood.. thanks
Old 10-13-2016, 06:13 PM   #7
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
The alternator is attached at two points... bolts.
1. Loosen only the top bolt.
2. Using a permanent marker just draw a straight line across that top . This is just for reference.
3. Using a long pry bar...or something long that will give you some leverage, you would just barely move the alternator towards you.
4. Tighten and go start the car.
The squeeks and initial squelch should be gone. If not, go back through the steps to tighten the belt some more.
This is important: You are gradually tightening the belt because the water pump has bearings that could get messed up. You can mess them up if you over tighten. You don't want to turn a 30 dollar job (if replacing the belt) into a 200 dollar job (replacing the waterpump).
Here's a video:
It's for a 06 Scion XB....pretty much same engine. He did an optional step of adding temporary bolt, watch the full video if you want to do that. Otherwise just try to find a decent spot to put in the pry bar for good leverage.
https://youtu.be/E8MLQlK4Q0o?t=113
Old 10-13-2016, 07:08 PM   #8
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Be careful when doing this that you do not damage the Oil Control Valve for the VVTi system. Be aware of what you are using for a pivot when you use the pry bar
Old 10-14-2016, 09:44 AM   #9
For the OP's reference, here is the Oil Control Valve being mentioned. It is tucked in behind the alternator and several people have broken it by using that general location as a pry bar point for shifting the alternator forward. Come at the alternator from the side with a pry bar, not the top.
http://www.yarisworld.com/forums/sho...56&postcount=1
Old 10-14-2016, 11:32 AM   #10
aaron21339
Thank you so much guys, tightened it this morning it seems to have gone away. You guys were able to figure it out and when I took it back to my mechanic they couldn't, so thank you!
Old 10-14-2016, 11:35 AM   #11
NEexpat
Drives: 2009, auto, 4dr LB
Just my 2 cents.
If you are unsure about doing this you can do more harm than good.
Take it back to where that belt was replaced and ask them to tighten a bit.
Cheers, and welcome to the forum.
NEexpat is offline   Reply With Quote
Old 10-14-2016, 11:43 AM   #12
NEexpat
Lol, well disregard my post.
serpentine belt
Easy fix for Squeaky / Squealing Belt andrewmcg DIY / Maintenance / Service 44 06-04-2025 10:22 AM
Squealing Belt Noise Toyota3000 DIY / Maintenance / Service 3 07-23-2013 03:06 PM
squealing belt dferguson2 DIY / Maintenance / Service 9 06-19-2012 11:13 PM
Squealing Belt rossman DIY / Maintenance / Service 8 01-31-2012 01:58 PM
