Old 10-06-2016, 11:45 AM   #1
Coldhammer
Coldhammer's Avatar
Drives: Yaris XPF9(A) D-4D 2008
[SOLVED] XPF9(A) D-4D 2008 Fuel indication stuck
Specifications:
Toyota yaris xp9f (a)
Engine: Diesel d-4d 1'364cc 90bhp
Tank: 42 litters capacity
Error: Fuel gauge is propably stuck
Explanation:
Well i filled the car with diesel yesterday and everything was fine!
So i did 110km and I must say that I pressed the gas much more than usual
to 140km/h so as I expected my l/100km hit at 5.3
And of course I lost 1 out of 8 lines of fuel... pretty normal.
anyway because i don't like the 5.3 number... i decided to fill up again and reset it and so I did. And for my surprise the fuel gauge was still at 7 out of 8... anyway I tried filling it to the maximum "be able to see diesel in the pipe" but still 7/8.
Can anyone explain why and how to fix it?
Coldhammer is offline   Reply With Quote
Old 10-06-2016, 03:37 PM   #2
Before you hop all over a possible issue, run the thing for a while and see if it eventually works itself out. You're a bit quick to be calling a problem. If after several hundred kms of driving and a subsequent re-fill the gauge is still showing 7/8 then I'd say there is an issue to address.
Old 10-07-2016, 12:34 AM   #3
Coldhammer
Coldhammer's Avatar
And you are right! I did as you said and eventually the 8th square appeared! Thank god... thank you very much!
Sent from my SM-J320F using Tapatalk
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan kaboom New YARIS Purchase Forum 9 05-15-2007 02:58 AM
