Se Vende
Se venden los siguientes ITEMS en Conjunto o Indivualmente
Contacto: Abdiel Telefonos: 300-9649 o 6611-8178 Equalizador Kicker -KQ5 5 Band EQ 03KQ5 Descripcion: 5-Band Parametric EQ 2 Sets of RCA Inputs Frequency Ranges: Bass: 40 Hz - 90 Hz Midbass: 125 Hz - 250 Hz Upper Midrange: 300 Hz - 750 Hz Upper Midrange: 1 kHz - 4 kHz Treble: 6 kHz - 20 kHz Cut/Boost: +/- 12 dB Input Sensitivity: 950 mV - 9.6V Output Level: 7V RMS Front/Rear Fader Remote Bass Level Control: Control your Kicker amp's bass boost from the EQ EQ Defeat/Bypass Line 1/Line 2 Input Selector Dual Illumination Green/Orange Crossover Kicker KX3 Front and Rear High Pass Crossovers - 18dB/octave, Variable Frequency (35-400Hz; 20x Multiplier Option on Front Crossover) Sub Low Pass Crossover - 18dB/octave, Variable Frequency (45 250Hz) Bass Boost Variable to +18dB at 40Hz Remote Level Controller 24dB/octave Subsonic Filter Two Stereo Inputs with Parallel Input Option Three Stereo Outputs (5V rms) Signal-to-Noise Ratio - >110dB 1-year Sonic Electronix warranty Amplificador - Directed A1004 Amplifier 4 Channel Model A1004 Max Power Rating 1000 watts CEA Primary Power (power into 4 ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 85W x 4 CEA S/N Ratio (referenced at 1 watt/4 ohm) 81dB CEA Additional Power (power into X ohm, all channels driven, 14.4V supply ≤ 1% THD+N) 125W x 4 @ 2 ohm Freq. Range 20-20K Hz Damping Factor >100 Input Sens. 250mV to 7.5V Crossover var. 12dB 2-way Bass EQ Yes 8db RCA Output Yes, stereo Protection T,S,D,R,O,L Dimensions - inches W:16-7/8 H:2-1/2 L:13 Metric - mm W:273 H:63.5 L:430 Todo el Paquete se vende en $350, Individualmente, el AMP se vende en $200 y el Crossover y EQ se venden Juntos en $150. Se aceptan Ofertas.
Abdiel Hiram |
vi el post en latinol. Sha kicker... cuanto pide x el eq? tiempo de uso ..
Super Yaris Panamá 05 HB - 2NZFE 1.3L Engine - 068 Super White - Aem CAI - Trd Oil Cap - Rev 17" rims -Toyo 205/40/17 wheels - Vibrant Front Strut Bar - Tein-S springs - KYB Gas Shocks - Header DC-S 4-1- Tenzo-r steering wheel- Pioneer Avh-P 5750 |
Si, es de un compañero del Job que me pidio el favor. El tiempo de uso es promedio un año. Parece que quiere vender el Eq con e CRossover juntos. serian 150 ambos.
Abdiel Hiram |
