Old 05-24-2007, 05:10 PM   #1
How To Properly Break-In a Sub?
okay, i never owned a sub (other than my home stereo system), and i'll be installing my sound system in my car in a week (hopefully, just waiting for the radio installation kit and harness to come in). i was wondering how to properly break-in the sub. it's the 10" Alpine Type R (4 ohm) and M450 amp with a Clarion DXZ465MP HU. i have a few CD's that have a wide range of bass notes, ranging from deep and long bass notes to hard hitting notes. should i put the gains to the lowest position and listen to music at a decent volume? thanks.
Old 05-24-2007, 09:37 PM   #2
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
I was really curious to see the answer to this. I often wondered if the people that tell you to break in your engine like an Indy car felt the same way about subs?
blacksan is offline   Reply With Quote
Old 05-25-2007, 03:22 AM   #3
Razr
YRS WHOR
Razr's Avatar
Drives: White 2007 Yaris E-Limited 5dr
The most effective way to break in any speaker is to run it at its resonant frequency (fs) - it's at this frequency it'll get the most cone excursion per-watt, so you minimize the chance of overdriving it (power and heat wise), whilst maximizing the pyshical excercising of the suspension mechsanisms -which is what you're breaking in.
To do this you'll need a clean sine wave test tone as close as possible to the resonant frequency - you can get this with a tone generator, any one of a myriad of test CD's out there, or just a bit of clicking in something like Cool Edit Pro and a CD Burner.
Making sure that no other speakers in your system are receiving the sine wave tone, slowly turn up the volume until you get close to the speakers rated xmax (xmax = how far the cone can move from the center resting point). If you hear *any* mechanical noises back it off - you've gone too far, and it's really difficult to hear distortion at a single frequency.
Once you've got it up and running properly, remember your settings and run it on/off in 5 minute cycles for 1 hour and you're done - and have probably saved yourself a month of normal listening to hear what it *really* sounds like :)
Razr is offline   Reply With Quote
Old 05-26-2007, 10:37 AM   #4
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Now that is an answer.
eco is offline   Reply With Quote
Old 05-26-2007, 04:19 PM   #5
spkrman
Drives: 1
coming from the self proclaimed type R master ;)... i've broken in/broken more type R's than lugs on the yaris, and made people wonder how many 15's I have stashed in my car when I was running only 2 R 12's =)
every woof is different, some need to be babied, some you have to beat the shat out of... some hardly change after breakin.
The R, beat on it... play it loud and proud, but be careful to not drive to distortion. The sub will handle even moderate to heavy levels of clipping at that power level so don't be scared to crank it up.
If you don't turn it up, it will never break in... the whole idea of "be easy on it" to break a woofer in is generally counterproductive... although there are a few cases where the spec of the driver is changed very drastically after breakin... normally power handling is HIGHER before breakin, but in some drivers I've seen it be MUCH lower.
If your up for the effort, Razr's post is helpful. I'd do that cycle, and in addition, leave the sub playing overnight at approx half excursion with the track on repeat. After that even the tightest subs will have loosened considerably and will without a doubt be broken in.
The R, however, doesn't take nearly that much work, play it hard for a day or 2 and your done... When taken to full xmax, it takes all of 5-10 mins for it to be broken in. As a general rule of thumb, the above process works great.
And I have one R 10 in the car right now, for that matter :)
Old 05-28-2007, 11:46 PM   #6
hey spkrman, i can play it as loud as i want cuz the amp i got is too weak for this sub. it's not pushing that much air. my factory speakers on the other hand, lol...those things are moving like crazy.
i want to save up for a better amp some day.
Old 05-29-2007, 02:01 AM   #7
GuySmily
GuySmily's Avatar
Drives: 2005 Toyota MR2
I remember reading that having an underpowered amp is bad for a sub, but I don't know if it's true, and it doesn't make any sense to me.
How do you like that sub so far though? Seems like everyone is getting those Alpine Type-R's now.
GuySmily is offline   Reply With Quote
Old 05-29-2007, 08:02 AM   #8
Razr
YRS WHOR
Razr's Avatar
The quick answer to this is that it's much more difficult to hear distortion at low frequencies, thus it's much more easy to run your amplifier to the point of serious (and damaging) clipping (mega distortion).
The longer answer goes like this:
Every component in your system introduces a level of distortion into the signal chain, starting at your source unit and ending at your speakers. A typical source unit will add <0.01% distortion to the signal, a decent amp <1% and a decent subwoofer around 10%. Yes, 10%. Really good subwoofers manage 3% distortion across most of their bandwith, and maybe even touch 1% at frequencies higher up in their range, but 3-10% is very typical.
While 1% distortion on a good amplifier is usually fairly safe (1% clip = 1% of the duty cycle is DC voltage rather than AC voltage), 10% distortion gets really dangerous really fast (due to heat build-up in the voicecoil and the added stresses on suspension mechanisms at full excursion), but not *that* audible unfortunately, especially when you're having fun :)
So simply put, it's easier to drive a smaller powered amplifier into clipping when running a subwoofer than it is a more powerful amplifer. Hence why small amps are more dangerous for subs, voila!
Old 05-29-2007, 02:38 AM   #9
my set up's cool for now. but i don't know how soon i'll be getting another amp. do you know anyone who needs an amp? it's only been in use for a little over an hour as of right now.
Old 05-29-2007, 04:30 PM   #10
spkrman
Drives: 1
the amps arent dangerous, the guy pumping up the volume control and gain is dangerous :)
Old 05-29-2007, 06:08 PM   #11
oh yeah, the gains and eq. on my amp doesn't seem to be doing anything. the LP too. ????
Is MP3 AUX Jack Grounded properly? iseraph7 In Car Entertainment + Electronics (audio / video / alarm) 17 07-16-2009 05:51 PM
WHat is Yaris Break In period and how? marcus General Yaris / Vitz Discussion 3 01-19-2007 02:24 PM
Prison Break cont'd.... riceboy Off-topic / Other Cars / Everything else Discussions 1 09-01-2006 10:50 AM
speaker break in... twixt In Car Entertainment + Electronics (audio / video / alarm) 3 08-16-2006 06:42 AM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
