Old 10-03-2016, 09:19 PM   #1
Cigar_Maverick
Cigar_Maverick's Avatar
Drives: 2007 Yaris Hatchback
2007 Toyota Yaris Died and won't start
Good evening!
I purchased my Yaris a couple months back and have had no major issues with it. It has 110,000 miles on it. Tonight, leaving work, I made it a block away before it died and would not start.
Luckily, I was able to coast it back to the building and get it off the road. I have been reading a few posts on here trying to get a starting place. I saw this page as well: http://www.yarisworld.com/forums/showthread.php?t=45663
First off, it cranks fine. The engine light didn't come on. I don't have an Engine Immobiliser System. I checked all of the fuses by the battery and didn't see any problems.
I can sit in the car and put the key in the "Run" position. Should I hear the pump run for a second or two? Because I don't.
On sitting here reading these, in the past, occasionally it has cranked a bit more than I thought normal before starting. But having bought it used, I didn't have a "gauge" as to what is normal.
The car is a 5 spd hatchback if that helps any. I'm going to borrow a company car to go home and look at this tomorrow.
Cigar_Maverick is offline   Reply With Quote
Old 10-03-2016, 09:28 PM   #2
bronsin
bronsin's Avatar
Is the check engine light on?
If it is you need to be able to read the codes.
Old 10-03-2016, 09:34 PM   #3
Cigar_Maverick
No check engine light.
Old 10-03-2016, 11:01 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
You're going to need a volt meter.
Check for power on both sides of all the fuses for one.
EFI and I think it's AM2 are essential.
Also, Check all the grounds bolted to the head on the engine. On my '05 the computer is grounded there. When I changed my engine I forgot to tighten it down and at random, 3000km later it came just loose enough to kill my car after I had been driving for 45 min.
Old 10-04-2016, 09:13 AM   #5
Cigar_Maverick
Bluevitz-rs, I'll grab a volt meter. Are the fuses I need to check under the hood or under the dash? I found this fuse "Map" http://www.autogenius.info/toyota-ya...e-box-diagram/ Which ones do I need to check?
I'll locate the grounds and check them. Any idea where they are on a 2007 Hatchback?
will it bump start?
thebarber, When I realized it had died, I tried that while it was coasting. I couldn't get it to go.
Sounds like it's your alternator. If you can, try testing the battery to see what the voltage is then take it out and put it on a battery charger. When you put it back in your car and start it, unplug the negative terminal on the battery while the car is running. If the car dies out, it's definitely your alternator. You can probably find one on ebay or a local junkyard for a reasonable price.
07liftback, The car cranks really well, but won't start. If it was the alternator, would the battery still be "UP?" Also, I'm going to have to figure out how to start it before I can unplug the negative terminal.
Like I said, when I cycle power I don't hear the fuel pump. Not sure if that is normal or not. If it is normal, I wonder if it is something like a crank position sensor?
Old 10-04-2016, 06:38 AM   #6
will it bump start?
Old 10-04-2016, 07:23 AM   #7
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
07liftback is offline   Reply With Quote
Old 10-04-2016, 10:18 AM   #8
Bluevitz-rs
With the key in the RUN position, what light do you have on on the dash.
Old 10-04-2016, 10:55 AM   #9
Cigar_Maverick
Looks to be the oil light, check engine light, brake light (emergency brake is on), battery light and cool engine light.
Not that it matters, but ignore the clock. In a desperate attempt last night to not have to take a company car home, I removed the ground from the battery for a few minutes in a futile attempt to get the car to start.
Old 10-04-2016, 11:00 AM   #10
All normal.
Old 10-04-2016, 11:18 AM   #11
Bluevitz-rs
Ok it's probably not computer problem. You'll need to pull the rear seat cousin and fuel pump cover and check for power as you crank the engine at the fuel pump.
Old 10-04-2016, 11:37 AM   #12
Cigar_Maverick
OK, That sounds easy enough. Gonna use AAA to get it towed back from work to my shop at home and get to it tonight/this week. I'll be in touch as to my results. I did download the service manual that somebody posted, so I hopefully will have a leg up getting to the fuel pump to test it.
Any particular threads in the forum stand out as to a guide for doing this as well? Sometimes the service manual can be a bit Greek to me when it comes to electrical testing.
From this:http://www.yarisworld.com/forums/showthread.php?t=45663
I got this:
For the wires on the fuel pump itself, the black wire is +12 and the white/black is ground.
Thanks again,
Russ
Old 10-04-2016, 10:52 PM   #13
Cigar_Maverick
Good evening!
Got the car home and removed the bottom seat cushion. Pried up the cover.
Note: do I need to apply any adhesive to reapply the cover?
Then I blew out the area with an air gun to remove dust/dirt.
This picture is of zero voltage with the ignition off:
This is a picture while the engine is cranking:
Based on this, is it safe to assume the pump is shot? If so, I can hopefully get one on order for weekend delivery.
If I'm to get a fuel pump, I'll likely shop Rockauto.com. Looking at two options
  1. CARTER P76424 {#2322021132}
  2. SPECTRA PREMIUM / COOLING DEPOT SP9031M
The 2nd option is a complete kit and the 1st is a Pump & Strainer Set. Thoughts?
Thanks,
Russ
Old 10-04-2016, 11:08 PM   #14
Bluevitz-rs
Next would be to confirm there's no fuel pressure. If you can open the big screw thing to get the pump out and confirm it isn't running and there's no fuel pressure first. Better to be 100% sure the pump is dead.
Old 10-05-2016, 02:21 PM   #15
Cigar_Maverick
So that I could have it prior to the weekend, I did order the pump. I can always ship it back.
Is there a particular thread that discusses checking for pressure at the pump? In an entirely scientific way (sarcasm intended), I put my ear down to the "Big screw thing" while the engine cranked and didn't hear anything. I don't know how loud they SHOULD be as I've never listened for one on a Yaris before. Betting they are way quieter than my Holley external pump on my Monte Carlo!
Old 10-05-2016, 08:30 PM   #16
The Yaris pump is very noisy, so if you can't hear it from above it isn't running.
Old 10-05-2016, 10:56 PM   #17
Cigar_Maverick
Should I perform any further tests or just wait for the fuel pump to arrive from RockAuto?
We were in the shop at home. No external noises, aside from the engine cranking, to cover the noise of the fuel pump. It was not running.
I guess if there is power to the pump while the engine is cranking, and there isn't a hum from the tank, then that seems a pretty strong sign the pump is shot.
I figured if it was something else, I could return the fuel pump.
Before I dunk the new pump in the tank, I can hook it up and see if it comes on.
Anything else I should be checking or doing while I have this open?
Thanks,
Russ
Old 10-08-2016, 04:32 PM   #18
Cigar_Maverick
Update:
Went and bought a Lisle - Fuel Tank Lock Ring Tool after figuring the retainer was NOT coming off without something. Followed the instructions on the manual I downloaded from here to replace the pump. With the tool, the entire thing was only about a 1 hour procedure. In the end, the Yaris fired right up and pulled itself out of the shop under it's own power. Success! Now just need to take it out on the road for a test drive.
Thanks to all who helped me.
Russ
Tags
cranks, dead, pump, won't start
