Old 11-20-2016, 01:51 AM   #1
Ramon1691
Ramon1691's Avatar
Drives: 2007 Yaris hatchback
Alternator voltage
Hello hope someone can help me out what should be the normal voltage for the alternator on the Yaris? Because mine is showing 13.70 to 13.60 under load I haven't tested with 2000 rpm yet and when I hooked up a tester it says that is charging within normal range but not strong on the 14 volt I got the tester at harbor freight tools if someone is interested in picking one up dirt cheap, mark my question is should I replace it now or wait till the light starts to flicker if it even does?
P.s i found a alternator at a wreck yard on a 08 yaris sedan with 8000 miles on it
Ramon1691 is offline   Reply With Quote
