Old 12-14-2016, 04:41 PM   #1
LMR48
Drives: Toyata Yaris 2010 Sedan
2010 Yaris Cigarette lighter outlet problem
I have a 2010 Yaris. I use the cigarette lighter outlet to power my GPS and XM radio. The problem is that whenever the power adapter is jostled, the power cuts off. If I reposition it I can find a spot where the power will come on again, until it is jostled once more. It is not the contact between adapter and socket that is the problem, I'm absolutely sure about that. No matter what adapter I use, same result. If the 12 volt socket is levered the slightest bit by the adapter, power cuts off. Any ideas as to what can be done about this? Thanks in advance for any advice.
LMR48 is offline   Reply With Quote
Does the Yaris Hatchback 2007-2008 have Cigarette Lighter Port? TwisteD General Yaris / Vitz Discussion 10 08-13-2015 04:15 AM
2008 Toyota Yaris Cigarette Lighter Replacement Kellieparenda DIY / Maintenance / Service 0 08-02-2015 07:05 PM
Cigarette lighter itzarthi In Car Entertainment + Electronics (audio / video / alarm) 5 06-09-2015 05:12 AM
