![]() ![]() Drives: 07 Yaris 2dr hatchback Join Date: Sep 2016
Not sure if I should change clockspring
I did the jumper wire thing in my car there are a crap load of codes that came up. 32,35,37,43,51,52,54.lm also not sure if this is normal, when I put the jumper wire on the engine light flashes and so does the p/s
light. Can anybody post a chart for these codes or tell me what they mean, any response would be great thanks. |
![]() Drives: 1L Yaris 2004 Join Date: Jan 2017
Here is the code list - http://www.troublecodes.net/toyota/
Your car is an 07 though right? That makes it OBD2 and you should just plug it in, the "jumper wire thing" is the old OBD1 thing. |
Thank you for reply
Yes it's a 07,im not sure if my friend has the right scanner for this car. I know a mechanic that will charge me $40 to read the codes. The list that you sent me, if the number is 51 then it's grouped under number 5?thank you for your reply.
Hubcap Enthusiast
Drives: '09 3-door 5-speed Join Date: Jan 2016
Most auto parts stores will read your codes for free. I know Autozone does. Or, if you have an Android phone or tablet, get a bluetooth OBDII dongle like this one:
https://www.amazon.ca/Docooler-V2-1O...dp/B009RLB4Z8/ Then, download the Torque Lite app (free) and scan the codes yourself, anytime. Don't pay somebody $40 just to plug in a scanner and read codes. Jeez. |
Thank you
I just ordered the scanner should take two to three days to come in thank you.
Just seen on Amazon a 35 dollar clockspring should I stay away from this or get it as well? If anybody could tell me if it's ok or not would be great.
I would phone your nearest Toyota dealer, you may get it done as part of the free recall.
Have a read of this - http://www.consumerreports.org/cro/n...call/index.htm |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| transmission fluid that indicate must change | susucosp | DIY / Maintenance / Service | 3 | 12-10-2011 11:51 PM |
| My Oil Change Help Me, Please! | JetfireK | General Yaris / Vitz Discussion | 6 | 01-09-2011 10:25 PM |
| MJ dead | 90tsi | Off-topic / Other Cars / Everything else Discussions | 28 | 06-26-2009 02:20 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
