Old 02-17-2017, 08:14 AM   #1
loricechris01
Drives: Yaris
2009 Yaris Start Up
Hi, I need a little help in trying to identify what is causing my irregular car startup. Whenever I turn the ignition the car would struggle to start and eventually not. And when I turn the ignition again soon after it would start without a problem. The RPM though when started is at 2000 which is pretty high. This happens every morning before heading to work and evening before leaving the office. Basically when the engine is cold. I have a VVti engine and oil and filter was changed a few months ago. Any one have any ideas?
loricechris01 is offline   Reply With Quote
Old 02-18-2017, 12:54 AM   #2
MadMax
MadMax's Avatar
Have you checked the battery? It's where I would start...
Old 02-18-2017, 09:24 AM   #3
dogsridewith
Drives: 2007 2-door hatchback
Cold Start
That 2000 RPM cold-started RPM may be normal/correct for that vehicle.
How long are you running the first-start-attempts that fail?
cold engine, rpm, start up, turn over, vvti
FS: Various Parts from a 2009 Yaris Hatchback Freestylin Items for Sale by private party 17 02-24-2016 09:36 PM
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 02:24 AM
Not sure where to start (2009 yaris)... Faith87 General Yaris / Vitz Discussion 37 03-23-2009 05:35 PM
