Drives: 2011 yaris Join Date: May 2017
Suspension issue
Hi, I have suspension issue with my 2011 yaris. Hope somebody could help. I can hear *tok tok* sound whenever i ran oven humps at moderate speed. TIA
Just a Gaijin
You better go to a local shop to get your suspension inspected if you can't do it yourself.
Also it's not really possible for me to find the issue without looking at it. One thing check if you can see oil leaking from your coilovers, if so they are probably toast. curious what the other think |
with that vague of info there is nothing we can do. Inspect the suspension yourself and if you don't know how to do that then take it to a shop to inspect for you. Simply stating that your suspension is making noise doesn't really mean much without you looking at it to inspect it. Almost all suspensions parts will make noise over bumps when they start to fail
simple things to check are ball joints an the sway bar end links.
![]() ![]() Drives: 2015 yaris L Join Date: Jun 2016
My guess would be the sway bar links.
Just a Gaijin
Correct i mean the shocks obviously springs don't contain oil :D
| yaris voltage issue | yaris2010RS | DIY / Maintenance / Service | 11 | 12-29-2012 04:20 PM |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 10:59 PM |
| Finishing my suspension | ChinoCharles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-15-2011 09:26 PM |
| Mystery Suspension issue Please help! | Yaris79 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 04-12-2011 10:50 PM |
| NSW Proposed Suspension Restrictions | Bella | Australia | 0 | 09-22-2010 01:51 AM |
