Old 07-15-2017, 07:24 PM   #1
rafhelp
Drives: Toyota Yaris 1.33 TR
Just a few questions about Yaris
This question relates to 2009 Yaris TR 1.33
1 - Does this car have a timing chain for sure? ( i thought with timing chain cars you can see the chain when you open the engine oil cap)?
2 - The manual says something like 0W-20 is the best engine oil...i used 5w-40 is that an issue. After adding 5w-40 and redex engin oil treatment the performance seems to have gone a bit worse with decreased MPG a bit.
So does 0W-20 really improve performance and fuel consumption?
rafhelp is offline   Reply With Quote
Old 07-16-2017, 09:08 AM   #2
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
!. Yes. I depends on where the oil filler is located. If it's on the chain case, then yes, you'll possibly see the chain.
2. Use the engine oil that Toyota recommend in your manual, i.e. 0W-20 or if really necessary 5W-30. Don't use engine oil treatment, why would it be needed? I'm sure there's something in the owner's manual stating not to. Any improvement in "performance and fuel consumption" I suspect is negligible with 0W-20 oil.
mrpj is offline   Reply With Quote
Possible new Yaris owner with questions. Dexlin1011 Third Gen Yaris General Discussion 10 01-24-2013 12:44 PM
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
HELP: Questions before buying Yaris 3dr S wlfbrg1.8t Performance Modifications 4 02-10-2009 12:43 AM
