Old 08-17-2017, 12:13 PM   #1
DarkShadowFox
Will these Fit and P+P On my 2015?
redacted for build safety
Old 08-17-2017, 01:07 PM   #2
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
They'll bolt up to your '15 no problem, but they are not going to be plug and play.
There will be wiring involved.
Taking a guess, you'll be converting your bulb connector(s) to the projector style, and you'll have to source power for the drl led's via a relay and a switch in the cabin/changing out the headlight stalk to an SE, or wiring it straight to a source that supplies 12v with ignition on.
I'm not sure if ccyaris finished wiring up his facelift conversion, maybe cc wil chime in.
If you lack driver skill, add horsepower.
deng is offline   Reply With Quote
Old 08-17-2017, 01:08 PM   #3
DarkShadowFox
doesnt sound too complex time to buy a solder kit
Sent from my LG-H918 using Tapatalk
Old 08-17-2017, 01:09 PM   #4
DarkShadowFox
i mean I already have DRL. whats the difference between the SE? i already can select DRL on my SE wouldnt the relays be the same?
Old 08-17-2017, 01:17 PM   #5
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
That I'm not sure. Getting your hands on the electrical diagram would be a good first step.
Best not to assume, that's how electrical fires happen.
Old 08-17-2017, 01:19 PM   #6
DarkShadowFox
More google.
Old 08-17-2017, 01:20 PM   #7
DarkShadowFox
does the wiring diagram follow the 2007 model plus?
Armrest fit to yaris 2015 Hada112 Cosmetic Modifications (Exterior/Interior) 4 09-03-2016 09:16 PM
2015 Yaris SE (m/t) - Week-One Impressions - The Good, The Bad, & The Ugly. Kalispel Third Gen Yaris General Discussion 53 04-29-2016 11:35 AM
2015 Honda Fit kimona Off-topic / Other Cars / Everything else Discussions 9 07-27-2014 04:56 PM
Driven: 2015 Honda Fit Thirty-Nine Off-topic / Other Cars / Everything else Discussions 18 05-25-2014 09:54 PM
2015 Honda Fit Thirty-Nine Off-topic / Other Cars / Everything else Discussions 40 08-14-2013 09:42 PM
