Old 09-16-2017, 10:46 PM   #1
GibbsYaris07
Drives: 2007 Toyota Yaris 3dr
DIY 2006-2011 Blacked-out Hatchback headlight housing
This weekend I blacked out my headlights. I couldn't find a DIY so based on past headlight from past vehicles I did it myself.
1. I did the usual dropping the bumper and removed the headlight housing (removed all bulbs)
2. I preheated my oven to 250 degrees, then baked for 5 minutes.
3. After 5 mins, I carefully removed the housing and with a flathead screwdriver I pried off the plastic lens along with carefully removing the amber reflectors. Watch out for the sticky adhesive. Repeat steps for the other housing
4. Now its time to mast off all the reflective areas to avoid overspray.
5. This is when I applied a light sand and then a layer of primer. I let it dry overnight, then the next morning, I applied three coats of gloss black.
6. Once dryed (after 2 hours), I applied additional black adhesive, put them back together then baked each housing for 3-5 mins just to secure the housing clips.
7. Time to reinstall the headlights. To top it off, I performed a oxidation clearcoat cleaning and it turned out looking good.
8. Im done
Thank you for checking out my first DIY on this forum. I'm relatively new here and I already received helpful advice from fellow members. I hope I could return the same.
The Gibbs Garage
2016 Lexus GS350 f-sport (my main car)
2013 Lexus RX350 (wife's vehicle)
2010 Toyota Tacoma (my second vehicle)
GibbsYaris07 is offline   Reply With Quote
Old 09-17-2017, 08:04 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Looks great! Nice job and thanks for the DIY. I always liked the look of blacked out housings. I was a member of a Chrysler site and many guys did projector retrofits. Something about putting my OEM headlight in an oven scared me, even though a lot of people do it with no negative effects. I did buy some actual aftermarket blacked out headlights for my van, but the optical quality and beam scatter was so bad as to make it undriveable at night.
I see you can buy projector refits for the Yaris on eBay. And they are actually pretty affordable too and they look pretty cool.
http://www.ebay.com/itm/Toyota-2006-...tZOB-P&vxp=mtr
For some reason, they will only fit a 3 door hatchback. I'm new enought to these cars to not know the differences between teh 3 door and 5 door.
Old 09-18-2017, 07:35 AM   #3
GibbsYaris07
I've done these headlight housing baking several times in the past and I only experienced one time where I accidently melt a piece of plastic (less than a inch). Even though the small part was insignificant, it was a learning experience. Just keep under 250 and watch for 3-5 mins, and you should be fine. One important factor is to not let the housing body touch the walls. Thx for the support
The Gibbs Garage
2006 Auto Hatchback - $9900 PickupYaris New YARIS Purchase Forum 7 07-16-2012 04:22 PM
2006 Yaris 4-Door Hatchback 06yaris06 Cars for Sale by private party 4 09-02-2010 05:13 PM
2006 Yaris Hatchback Replacing Stereo Head Unit help lauren24 In Car Entertainment + Electronics (audio / video / alarm) 11 07-01-2010 11:13 PM
Install kit for 2006 hatchback milothicus In Car Entertainment + Electronics (audio / video / alarm) 9 04-21-2009 07:49 PM
