carbot.org Maintenance Record
Hi All,
Just thought I'd pop up a link to a free site I like for keeping maintenance records on my cars. It takes a little getting used to, but you can select any maintenance items you want to monitor, plus set your own service intervals, based on manufacturer recommendations, if you like. It is based on imperial units but with an online converter you can easily enter values correspondig to the metric system. You can add one-time service items and print a report from the generate excel spreadsheet. Carbot will email you when it's time to perform a specific maintenance item. I'm sure there are lots of similar sites or apps available, but I like this one. https://www.carbot.org/
| 2012 LTA Land Speed Runs/Trails Main Event - new class record set | fnkngrv | Tracking, Racing, Auto-X Forum | 11 | 08-15-2012 06:52 PM |
| 4-wheel alignment for 5000 mi. maintenance????? | Yari-Chan | General Yaris / Vitz Discussion | 44 | 01-28-2011 09:00 PM |
| 60K Mile Maintenance | Pattycake | DIY / Maintenance / Service | 20 | 11-17-2009 02:34 PM |
| Question about required maintenance | gm830 | DIY / Maintenance / Service | 9 | 11-04-2008 03:14 PM |
