Old 09-26-2017, 01:05 AM   #1
imran.niaziccl@gmail.com
Costello
Drives: Yaris 2012 Manual
Throwing no codes still dropping Rpm! help
I own Yaris 2012 manual transmission and from a couple of months I am facing a problem of dropping RPM which only occurs when I switch on AC.I live in Riyadh which is hot throughout the year. I did computer testing and it was showing the code for a faulty throttle pedal sensor which I replaced with new one and also replaced Airflow sensor which resolved the acceleration problem but dropping RPM still remains.Car, when driving in traffic and pressing clutch, drops rpm to 5 or 4 and then revs back to 1.2 and keeps on doing it until I turn off the AC or manually revs the throttle to stay at 1. Dropping RPM does also occurs when driving at the night with the lights on so I also checked the battery but battery voltage is alright, now the car is not showing check engine or any sign.I went to different mechanics and everyone says that on the idle car is working fine and go for computer testing again.As I am expat and I am having trouble finding good mechanics here I will appreciate if someone knows what to do solve the problem
PS link of video showing dropping rpm of my car is below
https://youtu.be/YuiiSCSpDes
//https://youtu.be/YuiiSCSpDes
imran.niaziccl@gmail.com is offline   Reply With Quote
Old 09-27-2017, 08:24 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
have you cleaned the throttle body?
Old 09-28-2017, 06:25 AM   #3
Costello
Yeah first thing mechanic did was cleaning the throttle body but still same
Is there any way I can increase the idle rpm of the car?
Old 09-28-2017, 10:54 AM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
Idle should be about 550rpm. And 800rpm with AC with a warm engine.
Mine idles at 1100rpm on a cold engine.
I've read alot about people complaining about the idle fluctuating on this engine.
Also, did you check PCV?
Throwing codes P043E, P043F, P2401, P2402, P2419 47_MasoN_47 DIY / Maintenance / Service 17 10-14-2017 12:19 AM
:( Check Engine Light with dropping Rpm imran.niaziccl@gmail.com DIY / Maintenance / Service 9 06-01-2017 03:30 AM
Which parts chain = best 2C re throwing codes?...Or is dlr w/Techstream needed? nookandcrannycar DIY / Maintenance / Service 4 01-18-2015 08:18 PM
What are these codes Yaris sedan is throwing? detroiter DIY / Maintenance / Service 2 11-28-2012 11:44 AM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 04:40 PM
