![]() Drives: yaris 07 Join Date: Aug 2009
Display does not show what gear I am in
the yaris we just bought dosen't display what gear you are in (D, R, 2, 1, etc) it is just blank.
any ideas? |
The shift positions go to the ECM as separate inputs and then the position is sent to the cluster as a CAN Bus message, so the two things I would check are:
1. 10A GAUGE fuse in the fuse panel under the bottom of the dash. 2. Make sure the 9 pin connector on the automatic transmission is plugged in.
Thanks so much Scott! I'll report back
I'm pretty sure the earlier Gen 2s didn't feed the dash display. My '06 dosen't even though you can see on the cluster where the indicator would show.
Drives: 09 1.3 auto Yaris 3dr silver Join Date: Jan 2018
Is there any chance to make it work?
| Motion Auto Show 8/21/11 | cali yaris | California | 2 | 08-20-2011 12:50 PM |
| Rockland Toyota's Scion Revolution 4.0 | phyre76 | NY / NJ/ CT / PA | 70 | 08-11-2010 05:20 AM |
| ROCKLAND SCION'S FALL FESTIVAL 2009 9/13/2009 | ROCKLAND TOYOTA | NY / NJ/ CT / PA | 18 | 09-15-2009 10:31 PM |
| ROCKLAND/SCION SUMMER SLAM 3.0 7/19/09 | ROCKLAND TOYOTA | NY / NJ/ CT / PA | 198 | 08-05-2009 01:04 AM |
| Rockland Toyota/Scion Car show | Zefoxe | NY / NJ/ CT / PA | 47 | 05-26-2009 08:16 PM |
