![]() ![]() Drives: 07 yaris Join Date: Dec 2016
Having brake issues
Having issues with the brake pressure in my 2007 yaris sedan. When I first start up the car I have no brake pressure and can't stop. Once i get going down the road a bit the brakes work perfect again. Seems to only happen for a few seconds after start up and driving. Anyone have an idea what could my problem be?
So, you don't have any power assist?
Nope I loose break pressure (and car can't stop) for a few seconds on a cold start of the car. After driving for a few seconds it seems fine again
I guess you can look for wet spots anywhere. My guess would be the master cylinder is bypassing.
Is the brake pedal hard, or you push and it goes to the floor?
Sent from my SM-G930W8 using Tapatalk |
![]() Drives: 2007 silver auto stock sedan Join Date: Mar 2018
I just rear endend a focus yesterday cuz my brakes went to the floor. Broke my grille but did nothing to their car go figure.
Sent from my VS996 using Tapatalk |
#7 | |
#8 | |
![]() Sent from my VS996 using Tapatalk |
Pull hand brake if you are not getting brake response...
IMO you shouldn't have driven your car when you knew you had brake problems. Brake fluid should be changed after a while AFAIK. Sent from my SM-G930W8 using Tapatalk |
#10 | |
No you don't, or you find another way to get to work and not put others or yourself in danger.
#12 | |
#13 | |
What if you just FUCKING DIED while going to work with a broken car? Hope you kill someone with your car. Sent from my SM-G930W8 using Tapatalk |
Alright guys enough with the arguing haha I'm just wondering why my cars brake pressure was temporarily lost for a few seconds. On a side note it was fine today never had any trouble at all. This is a weird problem
Yaris brakes malfunction
OP will get better advice here if e answers this question. (A pedal on the floor or a high pedal w/ failed boost will both reduce "brake pressure," but would likely have different causes.)
#16 | |
Now, op already checked for brake line leak, and bled. Provided he did good/proper maintenance, all I can think of is the master cylinder having issues. Eitherway, OP said his pedal went to the floor, I did suggest it was the master cylinder, stop driving the car as it is very dangerous.But well, looks like I know nothing, so I'll just let OP drive his car around trying to kill some innocent people Sent from my SM-G930W8 using Tapatalk |
Please note that there are two individuals with brake issues contributing to this thread.
The OP did not make the statements you are referencing.
#18 | |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 09:50 AM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 09:05 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 08:34 PM |
| Help! Brake light issues! | Prohibit | DIY / Maintenance / Service | 17 | 05-23-2011 08:33 PM |
| Rear brake adjust issues 07 Hatch | Tardis | DIY / Maintenance / Service | 4 | 03-20-2010 06:49 PM |
