lower rod ratio
has anyone ever lowered compression by lowering rod ratio? i was noticing the long stroke the 1nz has, and if i lowered the stroke and increased the piston width, i was thinking it would move the torque curve out 500-1000 and add 1000-2000 on the top end, (maybe more) where the turbocharger is producing higher boost.
i have not done any research into what rod lengths are available/ commonly used, it was just a thought i had all day yesterday. |
| Lower control arm replacement 2005 Echo ? | Infinitrium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-27-2012 04:23 PM |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 04:54 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | General Yaris / Vitz Discussion | 5 | 12-10-2009 07:49 PM |
| Yaris wheel rate ratio (06+) ? | dsc_pat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 07-05-2007 06:43 PM |
