Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 02-11-2018, 09:18 PM   #1
vasili99
Drives: Yaris 2007
Alloy rims for 2007 Yaris hatchback
Looking for a clean set of alloy wheels. Am in Montreal, Quebec, willing to travel to environs, or pay reasonable shipping.
vasili99 is offline   Reply With Quote
Old 02-27-2018, 07:08 PM   #2
David C
Drives: White '07 3dr LB
Hey, I'm in Montreal too, same car as yours. Welcome to the forums.
Little hint, you can grab pretty nice looking Mazda Miata wheels for $100 or less easily around Montreal. They both share the same 4x100mm bolt pattern and 54.1mm centre bore, as well as 14x5 and 15x6 rim sizes. Plus they are usually pretty lightweight (~13lbs for a 15x6 alloy mag and less than 12lbs for 14x5 alloy mag).
Old 02-28-2018, 06:47 AM   #3
14" Miata daisies dont fit
Search kijiji for 4x100
Or local car forums for honda and miata
Montreal racing forum, too
Old 02-28-2018, 08:40 AM   #4
David C
Whats a 14" Miata Daisies ? I have a set of 1996 Miata 14" 7 spokes mags on my Yaris for my winter tires and it's a direct fit. The 1996 Miata uses the same disc brake dimensions too, so the cooling and clearance were factored into the design of the mag.
Some Honda and Acura mags do fit also.
Old 03-01-2018, 01:15 PM   #5
Originally Posted by David C View Post
Whats a 14" Miata Daisies ? I have a set of 1996 Miata 14" 7 spokes mags on my Yaris fir my winter tires and it's a direct fit. The 1996 Miata uses the same disc brake dimensions too, so the cooling and clearance were factored into the design of the mag.
these don't fit. tried when i lived in New Brunswick...they don't clear the calipers
Old 03-01-2018, 04:13 PM   #6
David C
Thanks for the info !
Your 7 spokes alloy "daisies" 14x5.5" are standard on '90 to '93 Miata, the ones have which are the 7 solid spokes made from '94 to '97 in 14x6" do clear the 2nd gen front caliper just enough to be safe, however I specifically asked the garage not to install any balancing weight on the middle portion inside of the rim, but rather on the outer portion of the inside to prevent any interference with the caliper (especially if one of the weight would start to break loose).
Any 15" should be a good fit, 14" you should measure the clearance first.
Attachment 59351
Attachment 59352
Old 03-01-2018, 10:05 PM   #7
I had th 16" twist 5 spoke miata wheels...looked great
Old 04-05-2018, 06:03 PM   #8
David C
There's this guy selling the same Miata NA 14" mags that I bought for $100, for $775 with tires.
File Type: png Capture d’écran 2018-04-05 à 18.02.09.png (517.7 KB, 64 views)
Old 04-08-2018, 02:09 AM   #9
1zzVitz05
Drives: Echo 05
https://www.kijiji.ca/v-pneus-jantes...ationFlag=true
heres my set,was on my 08 yaris.
1zzVitz05 is offline   Reply With Quote
Old 04-08-2018, 08:16 AM   #10
David C
Originally Posted by 1zzVitz05 View Post
I saw those a few days ago. Never thought they belong to a YW member !
Old 04-08-2018, 09:17 AM   #11
1zzVitz05
Drives: Echo 05
Yeah im trying to sell them cheap because i already have my new set with tires. I thought these wouldve sold quick with the price i put on them, but still havnt had any offers, not even any interest at the moment...
Old 04-08-2018, 09:21 AM   #12
David C
Maybe it's because the paint job doesn't look very legit from the pictures ?
Old 04-08-2018, 10:40 AM   #13
1zzVitz05
Drives: Echo 05
They are dirty, but indeed, they arnt 100% top notch, they are straight, no curb rash, but theyd need a refresh. I am not looking to sell them for 400 either. Price is self explanatory.
Good, wide wheels for cheap!
Someone could as well pick them up, refresh them with new paint and flip them. Id do but i have to many projects at the moment.
Old 04-08-2018, 02:50 PM   #14
David C
I understand where you stand, perhaps if you'd add some of that in your add people would catch on the deal a little faster.
Old 04-08-2018, 02:51 PM   #15
David C
And for the Op, there's a bunch of Honda mags for $40 a piece with tires on them waiting for you at Kenny U-Pull in La Prairie. Lots of them in very nice condition. Just got back from there.
07 Yaris Hatchback Sir AY New YARIS Purchase Forum 19 03-16-2016 11:51 AM
LTB cargo cover and alloy rims for 09 Yaris HB DataGoddess Willing to Buy by private party 4 07-30-2015 05:05 AM
Who has a list of compatible Toyota rims for Yaris? Yawesh General Yaris / Vitz Discussion 5 01-17-2009 10:29 PM
