![]() ![]() Drives: 2015 yaris hatchback Join Date: Jan 2018
spoiler install
my 2015 4dr LE Hatchback didnt come with a spoiler. if i get a toyota oem spoiler, is drilling required for installation?
The one you have pictured can be held on with 3M tape only.
it can, but if you look at the little covers underneath; there are brackets in there that can be installed by drilling a hole and using included plastic inserts. (i used metal threaded inserts and a bolt) also, i believe there are 2 plastic arrow clips on the spoiler that will have to be removed if you don't drill alignment holes. (if installed from factory)
![]() ![]() ![]() ![]() ![]() Drives: 2016 SE Join Date: Nov 2015
heres what mine looks like with the hatch up
probably doesnt help much ![]()
#6 | |
Factory installed would be drilled. I'm saying, for that particular spoiler, 3M tape would do the job. It's a scary thing to take a drill to your body panels.
im just a little lost because the spoiler in the pic is a factory toyota oem part.
you don't have to. the covers clip into place. they install the bracket for safety, but the drilling is easy;
-hand tighten nuts on bracket, spoiler side -hold spoiler in place where it is live forever -mark holes with marker -remove spoiler and drill holes -put tape on the drill bit at 5mm if you are scared of drilling too deep. -use touch up paint around bare metal it's super easy to do, but if you use just the tape, make sure to use some really good stuff, like VHB 3m |
i just got the spoiler off the internet with no guides and a broken LH cover XD how do i install this is there one way it fits on?
| DIY Sedan Spoiler Install | Kaotic Lazagna | DIY / Maintenance / Service | 36 | 01-19-2020 11:35 PM |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| DIY Hatchback Spoiler Install | skootdog | Cosmetic Modifications (Exterior/Interior) | 29 | 06-14-2016 04:44 PM |
| What would the labor costs be to install a spoiler? | JerseyJeff84 | Cosmetic Modifications (Exterior/Interior) | 11 | 08-22-2010 07:24 PM |
| DIY Sedan Spoiler Install Interest? | Kaotic Lazagna | DIY / Maintenance / Service | 28 | 09-11-2007 11:02 PM |
